Help me jrk
Discussion in 'SimTools DIY Version' started by Salvo224, Dec 22, 2015.
  1. Salvo224
    Salvo224 Member
    Militello in val di catania
    388Coins
    Hello everyone I have a problema.ho a sim 2dof with jrk 12V12 Pololu I configured the software and started the game engine followed the lead and managed to move the sim output testing. patch the game the start and go on the pista.i engines do not move but the virtual axes si.qualcuno can help me?
    151,467Coins
    +11,038 / 56 / -2
    Can you please post screenshots of your SimTool Axis Assignment settings and tell us what game you are creating a motion profile for.
    Did you run Game Manager as admin when patching the game and what path did you patch the game to?
    Does the SimTools Game Manager turn blue when the game is run?
    You will also find a great deal of information about setting up SimTools in the relevant FAQ section: http://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
  3. Salvo224
    Salvo224 Member
    388Coins
    il gioco è lfs e assetto corsa tardi se riesco a posto tutto il problema è che facendo cilindro di lavoro l'uscita di test simtool e pece quando iniziare il gioco non succede nulla
  4. Salvo224
    Salvo224 Member
    388Coins
    the game is lfs and ac later if I can place all the problem is that doing the test output simtool work roll and pitch when I start the game nothing happens
    151,467Coins
    +11,038 / 56 / -2
    Have you patched LFS for motion?
  6. Salvo224
    Salvo224 Member
    388Coins
    It is certain and virtual axes move
    151,467Coins
    +11,038 / 56 / -2
    Yes I understand the virtual testing works, but I need to clarify if you have patched LFS for motion in its install path, which would be something like this:
  8. Salvo224
    Salvo224 Member
    388Coins
    I've done this step but I have to do when I install simtool or after configured?
    151,467Coins
    +11,038 / 56 / -2
    It is fine to patch LFS once you have set the Axis Assignments, it really does not matter.
    Can you please post pictures of all your settings.
    You should start with surge and sway in the Axis Assignments.
    Does Game Manager turn blue when you run LFS?
  10. Salvo224
    Salvo224 Member
    388Coins
    Yes game on blue
    151,467Coins
    +11,038 / 56 / -2
    Pictures of all your settings, including the Tuning Center?
  12. Salvo224
    Salvo224 Member
    388Coins
    I have not configured the tuning center where is it?
  13. noorbeast
    151,467Coins
    +11,038 / 56 / -2
    In your system tray right click on the SimTools Game Engine icon and open the Tuning Center from the menu.
  14. Salvo224
    Salvo224 Member
    388Coins
    for now I'm at work at lunchtime place photos
  15. Salvo224
    Salvo224 Member
    388Coins
  16. Salvo224
    Salvo224 Member
    388Coins
  17. Salvo224
    Salvo224 Member
    388Coins
  18. Salvo224
    Salvo224 Member
    388Coins
  19. Rastus
    Rastus Active Member
    Sydney Australia
    11,518Coins
    @Salvo224 in game list should be the name of the game your playing not default!!
  20. Salvo224
    Salvo224 Member
    388Coins
