Help me jrk
Discussion in 'SimTools DIY Version' started by Salvo224, Dec 22, 2015.
  1. Rastus
    Rastus Active Member
    Sydney Australia
    11,518Coins
    @Salvo224 That looks better does it work now? did you remember to save it after the change?
  2. Salvo224
    Salvo224 Member
    Militello in val di catania
    388Coins
    I will put the LFS
  3. Salvo224
    Salvo224 Member
    388Coins
    I saved you at virtual axes now move everyone but no movement of the motors
    152,541Coins
    +11,085 / 56 / -2
    Going back to my earlier questions, what path have you used to patch LFS and did you have Game Manager running as root when you patched it?
  5. Salvo224
    Salvo224 Member
    388Coins
    C:/lfs I did not understand the question of game manager
  6. Blame73
    Blame73 Well-Known Member
    8,305Coins
    Ti ha chiesto se stavi usando Game Manager come amministratore quando hai fatto la patch di LFS
  7. Blame73
    8,305Coins
    Per le traduzioni usa https://translate.google.it/#it/en/
    Nei post metti sia la frase in italiano che in inglese, perché le cose che hai scritto sono difficilmente comprensibili
    In your posts use Italian and English, cause what you wrote is hardly understandable
  8. Salvo224
    Salvo224 Member
    388Coins
  9. Salvo224
    Salvo224 Member
    388Coins
    Allora vediamo se puoi aiutarmi tu
    Ho patchato il gioco non come amministratore,funziona simtool dal output testing se muovo le slide con il mouse.
    Quando parte il gioco gli assi virtuali si muovono ma i motori no .
    Il gioco è live for speed ho 2 jrk 12v12
    Then see if you can help you
    I patched the game as an administrator, works simtool output from testing if I move the slide with your mouse.
    When does the game virtual axes are moving but the engine not.
    The game is live for speed I 2 jrk 12V12
  10. Blame73
    8,305Coins
    You got no movement at all or just little movement, cause maybe you just have to lower those values. I don't have LFS but they seem to be high (compared to what I use in other games)
    Non hai alcun movimento o è molto piccolo? Forse devi solo abbassare i valori nel Tuning Center.
    I non ho LFS ma negli altri giochi uso valori molto più bassi.
    Per modificarli devi premere 'Capture min/max', inserire i nuovi valori, 'Save new settings' e stop capture
  11. Salvo224
    Salvo224 Member
    388Coins
    Non ho alcun movimento.che giochi usi?io ho assetto corsa rfactor raceroom
    I have no movement games that you are using? I use assetto corsa rfactor RaceRoom pcars
  12. Blame73
    8,305Coins
    Assetto Corsa, pCars
    Does it work with any other game?
    Did you try running the game, Game Engine and Game Manager as Administrator?
    Hai provato ad eseguire il gioco, GE e GM come amministratore?
  13. Salvo224
    Salvo224 Member
    388Coins
    ho provato solo live for speed,non ho il plughin ac alle 17 provo ad eseguire tutto come amministratore e ti faccio sapere le jrk le ho comprate ieri
    I tried only live for speed, do not have the plughin ac at 17 I try to run everything as administrator and let you know
    the jrk I bought yesterday
  14. Salvo224
    Salvo224 Member
    388Coins
    Il sim si muove con assetto corsa ma sembra un po' in ritardo con i movimenti
    Sim moves with race trim but it seems a bit 'late with movements
  15. Salvo224
    Salvo224 Member
    388Coins
    I movimenti sono piccolissimi anche facendo dal tuning centre il capture max/min
  16. Blame73
    8,305Coins
    Quando fa il capture devi mettere nelle caselle i nuovi valori e li devi mettere bassi , tipo nel surge metti 3 e -3, poi salvi e fai lo stop capture.
    Se non lo sai 'old' non è un commento positivo, puoi anche toglierlo. ti aiutano e metti 'old'? Potevi invece rispondere che l'avevi già fatto...
  17. Salvo224
    Salvo224 Member
    388Coins
    A chi ho detto vecchi?
  18. Salvo224
    Salvo224 Member
    388Coins
    io non ho detto vecchi a nessuno.non posso che ringraziare tutti dell'aiuto e mi metto a dire vecchi?
    I did not say to old nessuno.non can only thank all the aid and I'm going to say old?
  19. Blame73
    8,305Coins
    per ringraziare puoi cliccare su 'like' (le icone in basso a destra) tu mi hai messo 'Old' (l'icona con la clessidra)
  20. Salvo224
    Salvo224 Member
    388Coins
    scusami tanto avrò premuto old per sbaglio mi dispiace moltissimo caro amico....comunque tu ha delle impostazione da mettere e se puoi spiegarmi meglio come inserirli
    I'm so sorry I accidentally pressed old I'm very sorry dear friend .... whatever you have to put the setting and if you can explain better how to incorporate
