Help me jrk
Discussion in 'SimTools DIY Version' started by Salvo224, Dec 22, 2015.
  1. Salvo224
    Salvo224 Member
    Militello in val di catania
    388Coins
  2. Salvo224
    Salvo224 Member
    388Coins
    153,758Coins
    +11,149 / 57 / -2
  4. Salvo224
    Salvo224 Member
    388Coins
    Noorbeast would you have photos or files of txt softaware Pololu config? I use two motors 24v valeo
    Noorbeast avresti delle foto o il file txt del softaware pololu?io uso 2 motori 24v valeo
    153,758Coins
    +11,149 / 57 / -2
    • Agree Agree x 3
  6. Salvo224
    Salvo224 Member
    388Coins
  7. Salvo224
    Salvo224 Member
    388Coins
    you can not use the engines 24v to 12v? 24v 45nm. 12v 30 nm.vanno well to move only in the seat and 70kg of pilot?
  8. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
  9. Salvo224
    Salvo224 Member
    388Coins
    Ho solo un alimentatore che al massimo entro il 3oa quindi ho bisogno di un altro
