  1. hooshang
    hooshang Active Member
    275Coins
    Hi @speedy
    thank you for this solution that makes 3 AC actuator available simply
    but IMO you should better to drag Ard a little more to the right which the ARD usb port can have access
    from outside the electronic box.
    anyway this is exelent job
    thank you friend
    best regards
  2. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    @hooshang ... thank you my friend .
    BTW ... The Ard USB is intended to be connected to the internal onboard front USB of the computer if empty :D:D >>> like this costume red tape socket in my current DIY 2DOF controller ... Or using a normal USB cable connected to the PC back USBs .
    otherwise if you'll be using it in a separate box [2 of them for 6DOF ] ... So, there will be a plenty of space for the normal USB cable to be plugged in through a USB hole plus leaving a decent distance from the edge for bearing the cable load on the socket itself ... also like the above picture ... you'll have an Ard. reset button access hole + a TC at the Ard. side for the 12v computer power supply .
    they are all will have the same ground .:cheers
    • Useful Useful x 2
  3. speedy
    Alexandria , Egypt
    7,948Coins
    :thumbs:thumbs:thumbs:thumbs:thumbs
    Thanks Tom ... That's what I was looking for ...and just by using 2-3 meter RJ11 phone extension cords to the VFD's terminals ... and a 2-3m. stereo extension 3.5mm plug shielded cables for F.B. pots .
    13Ft-Long-RJ11-6P2C-Plug-font-b-Telephone-b-font-Phone-Extension-Cord-font-b-Cable.jpg images (1).jpg
    to be cut and soldered / fastened at the other end . :thumbs:thumbs:thumbs
    updates are coming ASAP .:D
  4. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,445Coins
    Hi @speedy, have you thought about just isolating through the Arduino RS232? I have done this before... Use a cheap TTL USB to Serial converter from ebay ($1 to $2) and isolate the TTL transmit from the converter using a 6n137 and connect to the Arduino RS232 receive pin. You don't even have to worry about the receive signal for normal operation.
    This bypasses the Arduino onboard USB to rs232 converter. Of course if you wanted to hack into the board you could just use the on board one.
  5. speedy
    Alexandria , Egypt
    7,948Coins
  6. speedy
    Alexandria , Egypt
    7,948Coins
    Finished ... :thumbs
    I've used the commonly used terminal connectors to be angled and welded directly on board with wide pads ... So you don't have to use extra searching for sockets of plugs or purchasing more hardware ...
    I guess this is more easy since this is easier to wire every thing correctly ...
    Here is the final arranged layer picture and the 1:1 printable PDF file ...
    PCI Opto-Copler copper side.pdf
    Edit :board external dimensions will be like this to be easy installed in your computer ...
    • Like Like x 6
    • Winner Winner x 4
  7. Pastrana
    Pastrana Member
    Argentina
    165Coins
  8. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    I tried to upload several of these versions, but none of them seem to contain an arduino sketch. They have the motor monitoring-controlling application, and the other file is just a brief 5 line text. I'm sure I'm not doing something right here. please help me
  9. Kirk
    Kirk Member
    Sr Software Engineer
    Texas
    15,087Coins
    2DOF, DC motor
    http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    In particular, SMC3 v0.7.zip is what you want, and set "mode 2" in the source file.
    edit: ie: change
    #define MODE1
    to
    #define MODE2
  10. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    Has anyone had issues getting the Configuration software to interface with the arduino? I keep getting a "cannot read arduino" upon startup.
  11. Pit
    30,510Coins
    do you mean when you are starting SMC3? Did you set the correct com port in the smc3ini file?
  12. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    You're a genius and a scholar good sir
  13. Pit
    30,510Coins
    No, I am reading the manuals :p joke aside, I'm just kidding (but you are welcome to study the manuals nevertheless...:D )
  14. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    I'm noticing that as soon as I turn the computer on the motor seems to start running. Is the arduino code stored onboard? How do I unload it? Where's this manual at?
  15. Pit
    30,510Coins
    hmm, in this case you have to go step by step though the SMC3 thread. The Arduino code is stored on the Arduino itself - you have to upload the SMC3 sketch first to the Arduino. Please go to the OP (first page on this thread) you will find all needed information there. BTW you need the Arduino software first to be able to upload any sketch to the Arduino, but this are basics usually IMO this should not to be mentioned...
  16. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    Everything is wired up correctly, but for whatever reason it's reading my motor as motor 2, which I find odd because I only have one motor wired up. It seems to jog the motor in a back and forth motion of increments of five degrees when I increase the pwm max setting. Changing the feedback limitation controls on the right has little effect on this. When I try to operate the motor in simtools, the arduino does light up as if communicating, but it's not receiving commands when I try output testing. suggestions? comments? derogatory statements?
  17. Kirk
    Kirk Member
    Texas
    15,087Coins
    2DOF, DC motor
    First, I would ensure that you don't have the Arduino IDE open when you launch simtools, particularly not the serial monitor, as the connection can't be shared, so it simtools won't be able to open the com port. If you ever accidentally do, close both, then open simtools.
    Ensure you are wired as described in the "MODE2" graphic and that in the INO sketch file, you have "MODE2" defined instead of "MODE1".
    It is (nearly) guaranteed this is why you are seeing the wrong motor.
    If you still have problems, because Pin 13 is unused (and attaches to the light), I would add additional code that enables it as an output in "setup()", turns it off, and on receipt of the first good command, turns it on. This will narrow your issues down to "1) wiring" or "2) communications".
  18. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    After getting some sleep and looking over the diagram they have listed on page 1 of this thread, I noticed my pin locations were indeed setup for motor 2, not motor one. This obviously solved my "why is the SMC3 configuration software only running motor 2" issue.
    Unfortunately I still cant seem to get simtools to drive the motor when I go to test the axis's. I noticed the baud rate was set for 9600 on the arduino serial monitor tab, so I changed that to 115200 to coincide with the second figure in the sketch. The first being 500000, which I have changed in the Interface tab in Simtools. When I turn the axis "on" the arduino does seem to light up as if data is being sent to it. As far as turning the Arduino IDE off before launching sim tools, I gave that shot. Though after reading over Simtools starter instructions it does note to load up the sketch before opening up the Game Engine. Do you reckon I have something configured incorrectly with the SMC3 configurator?
  19. Pit
    30,510Coins
    can you move the motors (correctly) by using SMC3?
  20. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    Define "correctly", It shifts back and forth in increments of 15 degrees. The speed is adjustable, but the angle doesnt appear to be.
