Showroom DIY 2DOF simulator
Discussion in 'DIY Motion Simulator Projects' started by Erwan960, Sep 27, 2013.
  1. aboodix5
    aboodix5 New Member
    Baghdad-Iraq
    328Coins
    design and size of platform? motor location and chaire center diagram
  2. promy
    promy New Member
    engineer
    Belgium
    250Coins
    Looks nice! I'm thinking of building my own 2dof chair with the same kind of setup (motors beneath the chair and not behind)
    Nice to get some idea's from yours ;)
  3. Salvo224
    Salvo224 Member
    Militello in val di catania
    388Coins
    Ciao ervan ho un piccolo problema....ho configurato il software pololu e muovendo i potenziometri a mano funziona tutto.
    Accendo sim tool configuro le interfacce 1 e 2 delle jrk faccio output testing turn on e muovo le slide con il mouse e funziona roll e pitch come da default....
    Patcho il gioco lo avvio scendo in pista e non si muove niente tranne i virtual axis
    Puoi aiutarmi?
  4. Blame73
    Blame73 Well-Known Member
    8,303Coins
    This hag got nothing to do with the thread. Open your own thread and surely someone will try helping you out.
    Also remember to add an English translation.
    Questo non ha niente a che fare con il thread. Aprine uno tuo e qualcuno ti aiuterà sicuramente.
    Ricordati di postare la traduzione in inglese della domanda (usa google translator se non riesci).
    Tra l'altro non specifichi di che gioco si tratta
  5. Salvo224
    Salvo224 Member
    388Coins
    ok thanks I made one for my in English
  6. iRacerSimulator
    iRacerSimulator New Member
    La
    348Coins
    I am totally a NOOB. This is my first post. I have spent a little time browsing the various simulator projects around here. Your system seems to be the right one for me. I am thinking of duplicating it exactly. It seems well thought out, and attractive. I currently spend my time on iRacing. I will be moving soon, so it may not make sense to build this rig just yet. But I may start acquiring some components and start learning about how the systems work. Thanks for posting about your rig. You have inspired me to give this a go.
  7. Salvo224
    Salvo224 Member
    388Coins
    I hope to be able to finish it took me time but in the end I'm coming to the finish and I am satisfied
  8. martin falz
    martin falz Member
    Deutschland
    228Coins
    Hello good work! Do not you have problems which the Fanatec pedals disable by the vibrations? I have it built exactly like you. Have but sometimes the problem that the usb dropouts have
  9. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
    I never had problems with vibrations at the pedals.
    The fasteners are strong and nothing has yet been detached.
  10. martin falz
    martin falz Member
    Deutschland
    228Coins
    no no not that anything on the seat .
    i mean i have the problem that the usb from fanatec pedals in the race a short disconect have.
    and i think this is from the vibration from the seat.
    what have you make that the usb port iss so strong
  11. Erwan960
    3,832Coins
    The cable itself passes into the grooves of the profiles and is covered with a piece of plastic which prevents it to exit.
  12. martin falz
    martin falz Member
    Deutschland
    228Coins
    hi
    thx .
    from where you have this?
    have you a link for this?
  13. Erwan960
    3,832Coins
  14. martin falz
    martin falz Member
    Deutschland
    228Coins
    Thank you.
    Have a nice xhristmas
  15. martin falz
    martin falz Member
    Deutschland
    228Coins
    Can you make a picture from the pedals Where the usb is?
  16. fortissimo
    fortissimo Member
    france
    161Coins
    very nice facility, good job:thumbs
  17. MotoGatto
    MotoGatto New Member
    Torino
    450Coins
    I looked all over his project ..
    spectacular but above all the balance of the structure ..
    reading all the posts I saw that his scheme ..
    which was the final decision ?
    Thank you and congratulations again !
  18. Erwan960
    3,832Coins
    The left version is the one I have chosen.
  19. MotoGatto
    Torino
    450Coins
    really thanks for your help!
    and to uncover the secrets of a sim really top !
    It will serve as inspiration :thumbs
  20. MotoGatto
    Torino
    450Coins
    sorry to bother you even seen your kindness ..
    You have antidepressant this final concept ?
