prilad
Burnout Paradise plugin 2.0.0.1
Simtools game plugin for Burnout(TM) Paradise The Ultimate Box
  1. yobuddy
    50,996Coins
    Teamwork is the key!
    152,003Coins
    +11,061 / 56 / -2
    And congrats to such a great team, we all deeply appreciate and benefit so much from all your hard work!! :thumbs
  3. bsft
    might be an issue @prilad with plug in, I have the game on a disc, (remember those) and I am not sure the plugin is working on it. I bought it about 6 years ago As its difficult to minimize the screen and check for data.
    I know with cracked version, its works perfectly.
    I dont have steam version though. I could try to register through steam to see if it works
    exe name is BurnoutParadise.exe *32
  4. bsft
    ok, i checked, when I go to patch the game, it asks me if i would like to install patch, and when I do put it in the right place, it DOES NOT tell me that patch is installed.
    I checked by re-patching another game and it tells me patch is installed
  5. prilad
    Dubna, Russia
    9,658Coins
    3DOF, DC motor, Arduino, 4DOF
    Hi, @bsft . Can you check what game version do you have?
  6. bsft
    yep @prilad , i will have a look and get back to you shortly
  7. bsft
    version 1.0.0.0
    created 13/12/2008
    @prilad
  8. bsft
    @value1 , did you need to know about the plugin issue?
  9. josemanuelrm26
    josemanuelrm26 my 2dof
    valencia
    - 8Coins
    Hello I have seen the plugin version 1.2 is to prepare yourselves for the 1.3 version of GameManager?
    It is that it closes the abriri the game.
    or can be installed 2 GameManager both version 1.2 and 1.3?
    thanks
  10. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
    I'm not having much luck with these plugins on v2.0... This one crashes simtools upon starting the game (steam version)
  11. value1
    15,025Coins
    Please try to start the game and only then SimTools GameManager. Let me know, if that works, please.
  12. Sarge
    - 181Coins
    Hi value1, I tried this but it still crashes simtools.
  13. ZestorNL
    ZestorNL New Member
    IT Generalist
    Amsterdam, NL
    - 97Coins
    Hi all,
    I seem to have some trouble getting this plugin to work. I installed it in SimTools 2 and patched the game. Upon start of the game it is detected by SimTools, but no telemetry is being received.
    Does one have to do anything else but install the plugin? A setting in the game or something? I could not find anything in the game settings about that. The version I use is non-steam, but I don't know if that matters ;-)
    Plugins for other games (like Assetto Corsa and Project Cars 2) work fine.
  14. ZestorNL
    ZestorNL New Member
    IT Generalist
    Amsterdam, NL
    - 97Coins
    Update: It seems I have version 1.1.0.0 of the game. Can someone tell me if this version is supported with this plugin?
  15. Jumping Coin
    Jumping Coin Member
    70Coins
    I know this game is a bit old but it's a classic, and I was just wondering if this plug-in still works with Simtools v2. I've installed the patch without any issue, but Game Engine doesn't detect that the game is running. The indicator remains green and never turns blue. Any suggestions?
    In case it helps, I'm running Burnout Paradise Remastered from Steam.
    Thanks!
  16. Marxman
    Marxman New Member
    South Africa
    - 32Coins
    I think the remaster is a different exe so unfortunately it wont work unless someone here can create anew plugin or maybe reverse engineer the old one.
  17. Jumping Coin
    Jumping Coin Member
    70Coins
    I figured that might be the case. Thanks for the heads up!
  18. yobuddy
    50,996Coins
    Try renaming the launch exe to the old name of the launch exe and see if it works.
    If it does, let me know!
    All plugins will be re-worked for v3, so any information I can get to fix any we have broken will speed things up for v3.
    Thanks guys!
  19. Frankie
    Frankie New Member
    16Coins
    Hey Team! Just bought Burnout Paradise The Ultimate Box on disc for PC. I was wondering if anyone got the telemetry working?
    I am rockin' a DOF Reality H3.
    Thanks!
