Want to make 3 axis simulator for fly games.
Discussion in 'DIY Motion Simulator Projects' started by grooste_lwd, Nov 23, 2015.
  1. trust928
    trust928 Member
    brazil
    435Coins
    hows this project is going?
  2. grooste_lwd
    grooste_lwd Active Member
    Nederland => Friesland => Leeuwarden
    123Coins
  3. grooste_lwd
    123Coins
    As far as I am now. Two new power supplies are 53 amps each. Work fine. What starts probleemjes. Wires question and multiple options. Mine worked viewing pictures.
  4. grooste_lwd
    123Coins
    I've discovered that most super thick wires are needed for 60 amps at 24v. Can be calculated on this page. Too thin cable is just not good. I'm going to make my cable 4 mm copper core. Here is the count: http://www.ledtuning.nl/nl/draadcalculator.
    • Useful Useful x 2
  5. grooste_lwd
    123Coins
    SAM_0949.JPG SAM_0950.JPG SAM_0952.JPG SAM_0953.JPG SAM_0954.JPG SAM_0956.JPG SAM_0958.JPG
  6. grooste_lwd
    123Coins
    my keybord fails, out of battery, see foto,s. my new box.
  7. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    I like your idea of the clear container for your electronics. :)
  8. Pastrana
    Pastrana Member
    Argentina
    165Coins
    Lindo proyecto
  9. grooste_lwd
    123Coins
    Today I did the primer. Will not rust. Engine and new cable provided.
  10. grooste_lwd
    123Coins
  11. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Looking good!
  12. grooste_lwd
    123Coins
    Frame is about ready. Go there now make engines on the frame. Here new pictures.
  13. Nanomx
    Nanomx New Member
    183Coins
    nice work man , look forward to get it working
  14. grooste_lwd
    123Coins
    I made Adjust able foot space. The wood plate wil wil be upgraded. Simple to se how it looks like :).
  15. grooste_lwd
    123Coins
    Today I started the simulator. Be at best been selling point for 2dehans car / simulator parts. www.kaabounparts.nl. This guy is super friendly and thinks along. Man is very friendly and gives some parts for free because he sympathy like and project man. I'm eager to catch up on stuff for the sim.
    Have ordered a heavy cross coupling. These are some rare these NL gekeurt be for car MOT :(. This can I pick up next week. Become a cross coupling of a drive shaft.
  16. grooste_lwd
    123Coins
    Am doing a VR motorcycle helmet. This has been made so far. And works well with need for speed shift. Helmet uses Freetrack. And ir 4leds and an 8-inch display screen. Use a webcam turned builds trust to ir. This helmet is constructed at night. So I call it the midnight version. This helmet came into my mind and I had to make. This is a successful test vr helmet.
    - Positive:
    Race feels very realistic. look around freely.
    Reasonably cheap for something super perfects.
    I'm going to upgrade this helmet. Or a new building. Make lighter. Battery pack. New helmet. On and off button. And if possible wireless VGA or HDMI signiaal. And a 9 brighter screen. Furthermore, this helmet that is better I had hoped. Need for speed shift may or may not stop it now. These helmet comes on the simulator and will replace the monitor.
  17. grooste_lwd
    123Coins
    Photos of the VR Helmet.
    • Creative Creative x 4
  18. grooste_lwd
    123Coins
    These days again been busy with the simulator.
    Upcoming improvements:
    - PSU prepared. 2 X 56 amps at 12 volts. Dual fan.
    - Adjustments remembered for the simulator . The simulator Is little too big. Can not sit well with the pedals! Too far away :(.
    - designed custom cross coupling. Made of four standing 25 mm bearings.
    Planned Improvements to the helmet.
    New HD display 250g HDMI. Old is 740 grams of s-vga.
    Motorcycle helmet will be replaced with welding helmet.
  19. grooste_lwd
    123Coins
    The design.
      114.6 KB
      762
    151,467Coins
    +11,039 / 56 / -2
    It seems very high and I still can't quite grasp how the motors link to the frame, but I guess that will be clearer later on.
