Driver motor
Discussion in 'Electronic and hardware generally' started by MotoGatto, Dec 31, 2015.
  1. MotoGatto
    MotoGatto New Member
    Torino
    450Coins
  2. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    For 24volt motors up to 120watts I would suggest this:
  3. Pit
    30,510Coins
    I do not see a problem to build a seat mover using the commercial racing seat ;)
    I was a little cautious abut the specs, 120W should be OK as well but you never know the peaks can shut down a h-bridge even if the motors are less current rated.
  4. MotoGatto
    Torino
    450Coins
    I know ... I bought MDF, if I can use MDF for furniture ok
    or try with the platform and when I see that at least moves
    I can think of design as your very top!
  5. MotoGatto
    Torino
    450Coins
    This video inspiration to me:grin
  6. pipis2015
    Athens, GREECE
    10,248Coins
    If you check my thread I use the dual vnh5019 on my project with 12volts supply(12v=more amps ~2x).
    I never had any issues with the h-bridge.
    But i have to confess I was skeptical too.
    I didn't think it could be better than a motomonster if you consider the price difference.
    But if you check the specs...
    20amps @ 24volts (500watts) per channel should be ok for "several" secs
    And
    30amps @24volts (750watts) fos some milisecs
    should be OK for stalling a 5amp@24volt(120 watt) mottor.
  7. Pit
    30,510Coins
    I am not talking about the specs, and I use them on 24v. I share my experience here which shows a significant less powerful bridge than expected by the specs you quoted.
  8. pipis2015
    Athens, GREECE
    10,248Coins
    I am sorry. I must have missed the part that you have used the dual vnh 5019... just saw the picture.
    The info that you post is very interesting though, because the numbers I quoted are not suposed to be theotetical specs but real-life test results that pololu "claims" that they have done...without heatsinks.
    Of course real life experience is always more useful than a bench test.
    Thanks for the info @Pit.
  9. Pit
    30,510Coins
    NTL your thoughts are very interesting and you are very welcome :)
  10. MotoGatto
    Torino
    450Coins
    Sorry if I write just today but the work takes me so long ..
    I tried the vndh but as I understand it these cards are to be assembled or am I wrong ??
    I ask because I want a simple solution is to connect you to configure ..
    thanks again for the valuable advice
  11. Pit
    30,510Coins
    The Dual VNH5019 are assembled by default, you have to stick the cooler and fan only
    https://www.pololu.com/product/2507
    ..and to connect to the Ard, of course.
  12. MotoGatto
    Torino
    450Coins
    then immediately buy a fan , and I did not understand a heat sink too ? @Pit
    It exists here on the forum explanations for this configuration ?
    I would like to understand the connections between Arduino and Pololu ..
    and how to configure it for simtools ..
    excuse the many questions
    so I can see it thanks
  13. Pit
    30,510Coins
    heat sink is even more important than a fan...
    The FAQ section is your friend...look for Arduino (I can advise to to try out the SMC3 code), the wiring is described on the Pololu page itself. If you have all gadgets together I can help if you struggle, but I do not help reading all needed information.
  14. MotoGatto
    Torino
    450Coins
    best friend section faq
    I tried the first time , I found , but I do not understand what to watch , I'm sorry for the translations are not good
    http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    http://www.xsimulator.net/community...mtools-arduino-and-write-profiles.123/history
    thanks again @Pit
  15. Pit
    30,510Coins
  16. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    Can someone give me some advice on configuring my potentiometer? I set it to what seems to be the middle position and have my seat level. I glue the pot onto the back of the drive shaft (my roll axis is powered by one large worm geared DC motor directly driven). Upon loading the sketch one would imagine it would automatically assume the starting position of the pot is where it wants to be, but instead it jobs the motor 90 degrees of center. What's going on here?
  17. Pit
    30,510Coins
    Please ask any questions in a separate (new or own) thread.
  18. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    How does a white guy go about posting a new thread?
    • Dislike Dislike x 1
  19. Pit
    30,510Coins
    Pardon? Your question has nothing to do with the topic of the thread starter, so I kindly suggest to open a new thread where your issues can be discussed. Thank you.
    153,818Coins
    +11,150 / 57 / -2
