  1. Pit
    30,490Coins
    8. Set Kp to about 400
    • Informative Informative x 3
  2. Pit
    30,490Coins
    and please, screenshots, photos, videos...many users are thinking "I have all done rightly" but at least this is not true ;)
  3. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    Here are some pics...I'm only running one Hbridge right now, do you think this might be the problem? I still can't test my axis's in simtools, and as this is my first time using smc3 configurator i'm not exactly sure how it's suppose to make my motor behave. It shifts back and fourth in increments of 15 degrees. I can control the speed via increases pwm max, but not direction or rate of travel. Any help would be good
  4. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
    @kimballfount ...
    So 15 degree limitation response comes from a feedback pot ... What kind of pot do you use ? Do you use gears with it ?...
    And, Try using Motion output in the utility ...
    you also have Sine , Triangle, Square, Motion, and Manual testing output modes ...
    In SimTools use CAPITAL LETTERS here ...
    • Useful Useful x 2
  5. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    Capital Letters! CAPITAL LETTERS!!!!! Yeah that solved it man, been messing with this thing for two days. Thanks man
  6. speedy
    Alexandria , Egypt
    7,943Coins
    Nice :grin ... now for further troubleshooting the 15 degree issue ... please start your own new thread and post more pictures for the mechanical setup there ...
    :cheers
  7. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,258Coins
    Great problem solving @Pit and @Speedy. You provide great support in this (and other) threads. Much appreciated!
  8. Pit
    30,490Coins
    Thank you for sharing a compliment, "but" all credit is going to other members like @noorbeast, @speedy (see the last postings) etc. etc. as well. ;) I keep in mind that you have written this great piece of software and you have spent a lot of your spare time, so we all advanced members should help when our help is needed by new inexperienced members (except commercial builders, that goes without saying) :)
  9. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,209Coins
    Ditto to @speedy............I would still be dead in the water without his continuing help...............
    • Friendly Friendly x 2
  10. speedy
    Alexandria , Egypt
    7,943Coins
  11. Gepsi
    Gepsi New Member
    engineer
    Mexico
    638Coins
    hi, I'n new here!!!! this is my sim... I'm undestanding the wiring for the 3 dof... mode 1... I can't find the complete diagram for the wiring!!!! help!!!!
  12. Gepsi
    Gepsi New Member
    engineer
    Mexico
    638Coins
    I just burn 2 monster moto and 1 arduino jajajjaja my power suply is 12v 30a... is it enough?? the motors seems to be insolated... but I'm a mechanical engineer don't undestand electronics so much...
  13. Pit
    30,490Coins
    hi, FI you will find all information on the first page... How can you power on the MMs before you did not check the wiring finally? And how you can be sure that you burned two MMs?
  14. Gepsi
    Gepsi New Member
    engineer
    Mexico
    638Coins
    I don't have idea of what I did... well... the motor was shorted :) jaja I went to see a friend and he point it out... but how do a wire the 3th motor??? with the 2od MM??
    and I have another problem... the motors rotate faster in one direction ¿?¿?
    152,087Coins
    +11,065 / 56 / -2
    You really need to put all of your questions on your own project thread, which you can create here: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
    On your project thread tell us about your simulator so members know what they are advising about.
    I am guessing you are using wiper motors but have not ground isolated them, but there is no way to be sure until you provide a lot more information about your simulator: http://www.xsimulator.net/community/faq/wiper-motor-mandatory-ground-isolation.25/
    • Agree Agree x 3
  16. minanke
    minanke New Member Gold Contributor
    Developer
    Hong Kong
    - 374Coins
    Hi, I'm not sure should I post to this thread or start a new one because my problem is regarding my motor. Since I'm using the SMC3 tools, so I try posting here first.
    This morning when I start up my SMC powered seat, one of the motor cannot fix to the start position and can freely rotate it around 10 degrees. Firstly I think it is because I forgot to plugin the USB to the computer. After I plugin the USB and start up the PC. I check the motor again and found out that I can freely rotate it but the other motor has successfully lock to the start position.
    Then I start the SMC utility to check the green feedback, and I can see the greened back move correctly when I manually rotate the problem motor. Look like the all is working just the motor has no power driven it.
    Then I switch the connection between the 2 motors, the working motor is working but the problem motor still has no power and free to rotate it manually.
    So is this mean the motor was burn or something else?
    I'm using this motor
    https://www.motiondynamics.com.au/worm-drive-motor-12v-24v-200w-180-rpm-20nm-torque.html
    Thanks for the help in advance.
    Mike
  17. fzxj520
    fzxj520 Active Member
    1,341Coins
    Hello RufusDufus
    I would like to ask how the case without using the potentiometer, directly in code settings to achieve non-linear scaling and scaling values defined?
  18. RufusDufus
    Adelaide Australia
    16,258Coins
    Can you give some more detail I don't understand what you want...
    SMC3 Scaling is only useful if you use a POT, otherwise just adjust the settings directly in Simtools.
  19. fzxj520
    1,341Coins
    Pot output is equal to Clip Input value ?
  20. RufusDufus
    Adelaide Australia
    16,258Coins
    The POT is used to "scale down" the values that are sent from simtools. If the POT is turned to Max then the values from simtools are left 1:1 (no scaling). as the POT is reduced the values from simtools are scaled down either linear or nonlinear depending on software config. When the POT is at minimum the values from simtools are effectively scaled to zero so there will be no motion and the motors will sit in center position. Note it only works on Motors 1 and 2.
    I use it to quickly fine tune the amount of motion from car to car. I tuned simtools with the POT at half scale so I can easily increase or decrease from default.
