My first Test seems not working
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by NewRider, Jan 14, 2016.
  1. NewRider
    NewRider New Member
    305Coins
    DC motor
    I installed Simtool and read the documentation and started LFS to watch out any response from the Game from the Output Testing /Virtual Axis Window.
    I patched the game correctly.
    The Game Manager says Game Running and from profile settings and made all the movements to 50
    I attached some photos to show out my settings.
    Any special settings in windows should be done or that is because LFS is Demo Version?
    Thank you
      64.3 KB
      676
      121.8 KB
      695
      100.5 KB
      655
  2. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    have you created a profile in game engine? post some pics from LFS profile from game engine not from game manager
  3. NewRider
    NewRider New Member
    305Coins
    DC motor
    I checked back everything after I read your post
    Seems not that difficult but there still no response
      195.8 KB
      659
      189.4 KB
      683
      198.8 KB
      674
      186.8 KB
      663
      123.8 KB
      646
    153,764Coins
    +11,149 / 57 / -2
    Can I just clarify, is this running on 6DOF rig?
    What are the interface settings?
    Did you run Game Manager as Admin to patch LFS?
    I am confused because you have set Axis assignments for a 6DOF yet the interface setting picture has no settings.
  5. NewRider
    NewRider New Member
    305Coins
    DC motor
    Hello Noorbeast
    I still have no hardware at all But I checked these check boxes just as try to have a response.
    I did not run the Game manager as Admin tp patch LFS, but I checked the game directory and I could find that the cfg fils has been changed and also cfg.bak has been created which is backup file as I think and the game directory is on C drive root.
    153,764Coins
    +11,149 / 57 / -2
  7. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
