My First Car Flight 3dof Motion Simulator Build
Discussion in 'DIY Motion Simulator Projects' started by NaeemAhmad, Jan 13, 2016.
  1. noorbeast
    152,676Coins
    +11,088 / 56 / -2
  2. Nick Moxley
    FYI Pgsaw will get more motor's in stock sooner than later. If i were you i would email him and inquire as to when you can expect the units we use to be back in stock.
  3. NaeemAhmad
    NaeemAhmad New Member
    Engineer BSEE
    California
    418Coins
    10-4. It appears Pgsaw has the 50:1 in stock, but the 25:1 out of stock as of this morning.
    I just received an email from Pgsaw. He stated he will be restocked within a months time.
    Until then, I will begin my framework build this weekend.
  4. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    My 50:1 are plenty fast, IM 240lb
  5. bruce stephen
    general contractor
    michigan
    9,115Coins
    i use 60:1 w only 41 rpm's with a long lever (105mm). its fairly quick. you will be good with the 50:1..
