6Dof Stewart Platform Motion Simulator
Discussion in 'DIY Motion Simulator Projects' started by DocLove, Jan 19, 2016.
  1. DocLove
    DocLove New Member
    Grand Junction, CO, USA
    492Coins
    Hey everyone, I'm brand new to this entire idea of home motion simulation, and I think the work you all have done is incredible. I am extremely interested in designing and building my own 6Dof motion simulator for both flight and racing simulation. As I have little experience in both engineering and fabrication I expect this will be a long project over the span of a few years. Right now I'm curious how to design a 3d model of a Stewart Platform in a program such as SketchUp or 3dsMax. Thanks for all the inspiration everyone, I'm looking forward to challenge ahead.
    153,770Coins
    +11,149 / 57 / -2
    There are plenty of online tutorials on how to use SketchUp but you can also hook it up to SimTools and drive a model with an actual game: http://www.xsimulator.net/community/faq/how-to-animate-sketchup-3d-model-with-simtools.209/
    A 6DOF is a complex and costly project so you may want to build a working model before committing either, just so you have an idea of what is involved: http://www.xsimulator.net/community/faq/build-a-working-model-to-test-your-design-ideas.216/
    Also have a good read through the 6DOF project threads: http://www.xsimulator.net/community/faq/list-of-6dof-projects.179/
  3. DocLove
    DocLove New Member
    492Coins
    Thanks for the links and the advice :) My plan is to first model the platform on my computer, then build a small scale replica, and work out how to deal with the software and electronics. I have about $5,000 to spend on the project right now, though I'd like to make sure I have the knowledge to put it all together before I start spending any kind cash.
  4. SilentChill
    20,601Coins
    With that much cash you could build anything you wanted ;)
  5. DocLove
    DocLove New Member
    492Coins
    That's the idea anyways :p I stayed up all last night learning to use sketchup, should have a working rough draft by the end of the day... I'll try to put up a video if I do
    153,770Coins
    +11,149 / 57 / -2
  7. bruce stephen
    general contractor
    michigan
    9,115Coins
    nice, cant wait
  8. DocLove
    DocLove New Member
    492Coins
    Is there a way to post sketchup files to my thread? My video isn't working out lol
    153,770Coins
    +11,149 / 57 / -2
    Just zip the SketchUp file and post it as an attachment. Others can then download it and run it in SketchUp.
    I included my settings in the earlier post to show how I had the Interface and Axis setup and that is handy if you want others to test something for you.
  10. DocLove
    DocLove New Member
    492Coins
    Hit a hiccup with the simtools controller in sktchup... For some reason it only outputs to axis 1, 2, and 3. Also I'm curious why it says requires sketchyphysics 3.7.1! in the top left corner. I have the 3.7.1 installed.
  11. DocLove
    DocLove New Member
    492Coins
    153,770Coins
    +11,149 / 57 / -2
    Before moving on to other things did you run the simple model I linked to with the settings I provided with LFS?
    I just want to verify it is all working before the complexity of a 6DOF model is added.
  13. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    You will also find axis 3 inverted ... maybe this next link will help ... plus maybe " I didn't try this " adding a 4,5,6 Axis in the ruby file " when edited as text" will solve your 6 DOF Single Interface output controller problem in SimTools .
    http://www.xsimulator.net/community/threads/sketchup-sketchyphysics-simulation-faq.7864/#post-95596
  14. DocLove
    DocLove New Member
    492Coins
    Thank's speedy, that was exactly the solution!
    153,770Coins
    +11,149 / 57 / -2
    Thanks @speedy, I have added both bits of your info to the SketchUp Guide: http://www.xsimulator.net/community/faq/how-to-animate-sketchup-3d-model-with-simtools.209/
  16. speedy
    Alexandria , Egypt
    7,948Coins
    Thanks @noorbeast ... I guess it will be like this ...
    require 'socket.so'
    socket = UDPSocket.new
    socket.bind("127.0.0.1", 3157)
    timer_id = UI.start_timer(0.01, true) {
    message, sender = socket.recvfrom_nonblock(100)
    message1, message2, message3, message4, message5, message6 = message.split(";")
    $axis1 = message1.to_f / 256.0
    $axis2 = message2.to_f / 256.0
    $axis3 = message3.to_f / 256.0
    $axis4 = message4.to_f / 256.0
    $axis5 = message5.to_f / 256.0
    $axis6 = message6.to_f / 256.0}
    153,770Coins
    +11,149 / 57 / -2
  18. DocLove
    DocLove New Member
    492Coins
    It's alive!!!
    • Winner Winner x 3
    153,770Coins
    +11,149 / 57 / -2
    Nice work @DocLove :thumbs
    Do you plan on making the SketchUp file available?
  20. DocLove
    DocLove New Member
    492Coins
    Most definitely, the model isn't quite up to snuff yet due to my original lack of knowledge using sketchup. There will be more versions to come :)
    • Winner Winner x 4
