Xmotion 2dof Arduino Motomonster
Discussion in 'DIY Motion Simulator Projects' started by spiroboy1, Jan 20, 2016.
  1. spiroboy1
    spiroboy1 New Member
    611Coins
    Jovens do forum!!
    obrigado pela recepçao
  2. spiroboy1
    611Coins
  3. spiroboy1
    611Coins
  4. spiroboy1
    611Coins
  5. spiroboy1
    611Coins
  6. spiroboy1
    611Coins
  7. spiroboy1
    611Coins
  8. spiroboy1
    611Coins
  9. spiroboy1
    611Coins
    Young, good afternoon. see if you guys can help me, I also built my simulator and I am with the following problem:
    Everything works fine until I connect my g27, then the computer stops sending data to the Arduino simulator. I'm using SimTools software and a single computer. Already checked the doors and no conflict. Someone had a problem like that?
    Thank you very much in advance !!
  10. Pit
    30,510Coins
    Hi, great rig - but you do not use make a 1:1 "picture:posting" thread ;) If you need coins for SimTools please ask.
  11. Pit
    30,510Coins
    Please check out SimTools with LFS and a keyboard as a wheel (do not connect the G27).
  12. spiroboy1
    611Coins
    Already tried! the same thing happens, restart the computer and everything works perfectly even connect the g27, then even if I disconnect the g27 contunua without transmitting data until I restart the machine again.
    my computer is AMD SixCore, 8GB memory and GTS450.
  13. noorbeast
    153,703Coins
    Should not be needed @Pit, I donated enough coins last Friday.
    153,703Coins
    Have you tried using a USB hub?
  15. spiroboy1
    611Coins
  16. noorbeast
    153,703Coins
    In that case it may be worth trying the G27 via a hub, a cheap one would do, just to see if that isolates the issue.
  17. spiroboy1
    611Coins
    ok young, I'll try and give a return.
    thank you !
  18. spiroboy1
    611Coins
    Jovens, eu tentei o hub e nada, levou o G27 e outra roda simples conectado e trabalhou toda normal. Eu não sei mais o que tentar.
    Jovens, Tentei o hub e nada, Tirei o G27 e conectei Outro volante Mais Simples e funcionou Tudo normal. nao sei Mais O Que tentar.
  19. spiroboy1
    611Coins
    Já verifiquei até o gerenciamento de energia USB e nada, esta tudo ok, instalei os drives atualisados do g27 e nada.
    I checked into the USB power management and nothing, it's all ok, I installed the atualisados drives the g27 and nothing.
  20. spiroboy1
    611Coins
    Young, I tried the hub and nothing, I took the G27 steering wheel and connected Another Simplest and worked all normal. I do not know what else to try.[/QUOTE]
