DIY 3-DOF Sim Car
Discussion in 'DIY Motion Simulator Projects' started by skano ca, Jan 20, 2016.
  1. skano ca
    skano ca tH3 bR1igHt3st star 1n the c0nst3llat10n HydRa
    engineer
    Malaysia
    102Coins
    Hi all,:D:D:D
    I have been reading as much as I can this 3 days. So i decided to build my own motion simulator, DIY 3-DOF Sim Car. :nerd
    Please keep in mind im a total newb to this type of project. Hopefully I ask the right type of questions, but any advise, feedback or creative criticism is welcomed and appreciated!:sos
    The project will starting by today. I will be posting photos along the way.:cheers
    154,520Coins
    +11,184 / 57 / -2
    You will find plenty to get you started in the FAQs, from design software, dimension of sims, to PSUs, pots, motors, JRKs, Arduinos and Motor Monsters and more: http://www.xsimulator.net/community/faq/
    It is a good idea to do a plan, even if it is a rough sketch and post it here, before you start ordering anything. That way members can give you some good advice on what parts may best suit what you have in mind.
    Good luck with your project.
  3. skano ca
    engineer
    Malaysia
    102Coins
    Just finished my drawingo_O:D:D 2016-01-20 22.43.11.jpg
  4. skano ca
    engineer
    Malaysia
    102Coins
    :nerdpls give comment.... anybody...:sos
  5. Jun
    Jun New Member
    South America
    7,048Coins
    I think a 360 sim it's a big challenge so I wish you good luck. :thumbs
    Cheers
    :cheers
    154,520Coins
    +11,184 / 57 / -2
    It is totally up to you what you build but if your focus is racing rather than flight I would suggest a shoulder mount design with traction loss, as it is far easier to build plus is highly responsive at relatively low cost.
    In my view your design as pictured would better suit a flight simulator.
    • Agree Agree x 3
  7. skano ca
    engineer
    Malaysia
    102Coins
    FYI I try to mixup all round sim in 1 rig, coz I like car racing game and flight game. Thx Jun and noorbeast for ur comments and suggestion. I will study ur suggestion... :nerd
    p/s maybe it could be roller coaster sim too:grin
  8. cgodwin
    cgodwin Active Member
    Engineer
    Eugene, Oregon
    2,478Coins
    Looks like it will be an impressive build. Kind of a similar design to mine, but I limited mine to 2DOF to make it smaller, cheaper, and easier to build. Still I've been shocked how long it is taking me and how much work it is. As others have mentioned, this type of design does work better for flight sim. Although if well built without too much backlash, it should give decent performance for racing also.
    I would recommend connecting the two outer frames together, unless that pipe section is cut out just for illustration purposes. I've been shocked how much force gets applied to the frame when changing motor direction, and that split frame looks like the weak link in your design. That is the one area you don't have to worry about weight, so it is best to overbuild it a little.
    Also I recommend pre-planning where the motors and linkages are going to go before staring to build anything. If possible, model the motion or at least carefully check that everything will clear as it moves to the limits. I though I had my design perfect in that regard, but I had to tweak some things once a built it because my linkages were hitting each other.
  9. skano ca
    engineer
    Malaysia
    102Coins
    Much-much appreciated to your comment... very good recommendation
  10. skano ca
    engineer
    Malaysia
    102Coins
    Looks easy...but never understand bfr try
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    monsters are 12 volt.
  12. Pit
    30,513Coins
    Use VNH5019 instead of the monsters if you need 24V drivers, but stay within the specs...
  13. Playsimulator
    Playsimulator Member Gold Contributor
    france la voulte sur rhone
    178Coins
    3DOF, Arduino
  14. skano ca
    engineer
    Malaysia
    102Coins
    I measured my real car:nerd and make me confusingo_O how to use these dimension to my design
    • Disagree Disagree x 1
  15. bruce stephen
    general contractor
    michigan
    9,115Coins
    the position of the steering wheel in most passenger cars is way to far away imo. you want the wheel as close to your chest as you can stand. This will give you more control as you are able to use a larger number of muscles to turn the wheel. the center hub of my steering wheel is only about 15cm from my chest. passenger vehicles are built for a wide range of body sizes and the designers also like to get the wheel away from the operator for collision purposes. build a mock up out of cardboard maybe and see whats comfortable for you. larger people do not fit in my sim. a friend tried and aborted his attempt at a ride due to his circumference (belly fat).
  16. Edson Lourenço Bezerra
    Edson Lourenço Bezerra Edson Bezerra - Desenvolvedor Open Source
    Analista de Sistema
    Jundiaí
    147Coins
    2DOF, 3DOF, DC motor, Arduino, Motion platform, 4DOF
    When creating my project was quite the diversity of people who would use it, the prototype would be tested diretamento the public to be dealing with a dream to take the inclusion of technologies the slums of São Paulo / Brazil. However if the project is focused for personal use and should be priorisado confornto.
    Use of recyclable materials or even wood to make a replica
  17. skano ca
    engineer
    Malaysia
    102Coins
    Starting cuting material into pieces
  18. SeatTime
    Nice drawing :thumbs, IMO you are going to need some big motors to overcome all the inertia of what will have to be a heavy frame.
  19. skano ca
    engineer
    Malaysia
    102Coins
    I totally agree wt you, but for 1st test run, will try fits it with scrapped motor I posses.
  20. IJOJOI
    IJOJOI Member
    Austria
    523Coins
    SCN5
    That looks like a big challenge!
    But I am really looking forward to what you are in process of creating!
    Btw, which materials will you use for the frame?
    As already mentioned, you will need VERY powerful motors to move the simulator quickly enough, especially if you are using VR (which I suppose).
    A heavy frame will not only drive up the expenses in Motors, but may also not achive what you are aiming for.
    This construction made out of steel frames will already weigh a lot... and aluminium may not be strong enough, or (more likely) is way harder to process...
    But who am I to question you, I am still studying mechanical engineering, so that's just an opinion ;)
    If you want, you can check out my project as well ;)
