6Dof Stewart Platform Motion Simulator
Discussion in 'DIY Motion Simulator Projects' started by DocLove, Jan 19, 2016.
  1. noorbeast
    152,676Coins
    +11,089 / 56 / -2
  2. SeatTime
    Nice work:thumbs , but don't spend too much time re-inventing the wheel in sketchUp :). The real work in building a 6DOF is yet to come.
  3. DocLove
    DocLove New Member
    Grand Junction, CO, USA
    491Coins
    Thanks for the confidence everyone :) Here's a newer version of the platform. There was a lot wrong with my last one :p
    152,676Coins
    +11,089 / 56 / -2
    Many thanks for that @DocLove, I have updated the FAQ SketchUp link to your new model.
  5. DocLove
    DocLove New Member
    491Coins
    So I've decided that I will use AC motors, Gearboxes, and VFD's for my Stewart Platform. It seems like there's a formula for picking parts based on platform wight but I can't find any info on it. Any help would be much appreciated.
  6. DocLove
    DocLove New Member
    491Coins
    Meanwhile I've been tweaking the design to get better movement. Something doesn't look right to me though. Any thoughts?
    152,676Coins
    +11,089 / 56 / -2
    I think it would help if the model was turned around so you are viewing its movements from the back going in the same direction as the car.
    It seems to me that sway may be inverted.
  8. SeatTime
    Do you have yaw enabled? Turn it off if you do.
  9. DocLove
    DocLove New Member
    491Coins
    Thanks guys turned the yaw off and inverted the sway at lunchtime, everything seems much smoother now. I'll try to get another video up of the result after work :)
  10. DocLove
    DocLove New Member
    491Coins
    With a better view too lol
  11. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
    Also make sure that you lean outward with curves not inward like a motorcycle ...
  12. speedy
    Alexandria , Egypt
    7,944Coins
    you have a list of a 6DOF projects in the FAQ with AC and DC motors ...
    you can start from there then join them at the end .:cool:
  13. DocLove
    DocLove New Member
    491Coins
    Thanks for the links speedy, still working out all the math for it but I've been getting a a much better idea of what I'm looking for.
  14. DocLove
    DocLove New Member
    491Coins
    Here's the video of my platform with the changed settings, as well as my Axis Assignments in SimTools. I think it looks like it's rolling the wrong way because the track isn't flat.
  15. bruce stephen
    general contractor
    michigan
    9,115Coins
  16. Blame73
    Blame73 Well-Known Member
    8,305Coins
    sway works the opposite way. Is inverted ( at least in my seat mover it is...)
  17. DocLove
    DocLove New Member
    491Coins
    Shopping list for my scale model: Purchased on Amazon
    • J-Deal® 10x Pcs SG90 Micro Servo Motor TowerPro 9G RC Robot Helicopter Airplane Boat Controls
    • RobotLinking 2015 New Uno R3 Project Ultimate Starter Kit For Arduino UNO R3 Mega2560 Mega328 Nano including Uno R3
    • Great Planes All Thread Rod (Set of 12), 4-40x12"
    • Du-Bro 900 4-40 Heavy Duty Ball Link (12-Pack)
  18. DocLove
    DocLove New Member
    491Coins
    I can print out the specialty parts at the place next door to my work :p
  19. DocLove
    DocLove New Member
    491Coins
    Electronics came in today, spent a couple hours figuring it out and hooking up wires... Much progress has been made XD
  20. Kirk
    Kirk Member
    Sr Software Engineer
    Texas
    15,087Coins
    2DOF, DC motor
    With that many servos, it's hard not to recommend Adafruit's 16 channel servo shield, or any of the clones.
    http://www.aliexpress.com/item/Free...erface-for-Arduino-Raspberry/32551764422.html
    ($3.28 w/ free shipping on AliExpress)
    https://www.adafruit.com/products/1411
    ($17.50 from Adafruit, shipping is extra, but it's the genuine thing).
    They are easy to connect up and much easier to code for, plus it's easier to configure a secondary power source to avoid brown-out on your Arduino.
    Anyway, when using I2C to control the servos, you basically just set the desired positions, no need to babysit the servos, and no need for jumper wires, the headers are all setup for attaching servos directly.
