6 DOF Wood Flight Simulator
Discussion in 'DIY Motion Simulator Projects' started by MagicEdge, Sep 16, 2015.
  1. MagicEdge
    MagicEdge Active Member Gold Contributor
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Worked on a little the simulators today. I can see a time to indulge again and pics will be posted. Thank all for inspiration,
  2. SilentChill
    20,604Coins
    About time ! chop chop we are waiting :D
  3. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Worked on the 3 Sim base again. All the glue, screws and support plates. It doesn't look like much done but requires a lot of time. :eek: I will post pics soon. Darkness fell and was more motivated to get as much done as possible.
  4. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Some pics of the 3 base units. I was going to use steel angle for motor mounts but have decided to use aluminum for weight savings and machine ability .
    20160131_172038.jpg 20160131_172105.jpg 20160131_172128.jpg 20160131_172223.jpg
  5. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    First pics of computers to be used for the 3 simulators. Another Silverstone mini ITX case with Eyefinity 6 is needed. Money money money money:p
    20160131_194721.jpg 20160131_194745.jpg 20160131_194800.jpg 20160131_194843.jpg
    154,520Coins
    +11,184 / 57 / -2
    I am a little confused, how many computers are you using to run 3 simulators? There is a stack of computer behind the 2 mini ITX cases, are they for parts or something else?
  7. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    The stack on the right is for multi-display and usb input for controls. One each per simulator and the stack on the left is for game engine control and any other feature needed to enhance the experience. The mini-ITX with eyefinity 6 will be used to do small displays for gauges.
    154,520Coins
    +11,184 / 57 / -2
    I will be interested to see it all in action, it just seems to me to be overly complicated when you could just have one computer per simulator doing all of that.
  9. Khanage
    Khanage New Member
    97Coins
    I feel like that part almost needs a post all to itself! Cool stuff! @noorbeast has a point in that you could probably accomplish all of that with one PC per rig but I'd still be quite interested to see how a multi screen gauge display comes out.
  10. SilentChill
    20,604Coins
    Wowzers that's a lot of hardware !!!! Are you still going for the Rift or are you going to use monitors ?
    Keep up the good work :)
  11. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Hey Craig, you are inspiration brother. Multi-monitor is going to be used. Curved displays are getting affordable and will wait until needed. Ordered the aluminum 4x6 angle yesterday. Thanks everyone.:cheers
  12. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    In work todayo_O:nerd
  13. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    I will post this week pictures of the mini displays that will be using ultraMFCD. Only the gauges that are display will be used. All others will be actually sim gauges.
  14. sliversgyj
    sliversgyj New Member
    - 27Coins
  15. sjmy
    sjmy i like a wind
    china
    194Coins
    2DOF, SCN5
    Great job!
    i have a flight sim game,but my simset only 2dof.
  16. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Here is what is completed. I am following all of you!:mad: The added corners will have 2 ply conveyor belt bonded to them.
  17. SilentChill
    20,604Coins
    Great work :) Coming along nicely
    • Optimistic Optimistic x 1
  18. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Slow down on simulators. Purchased a C5 Corvette with low miles. Lots of upgrades to high horsepower and suspension. A gearhead from 3 decades. 230 MPH is target. I will work on sims as time allows. Widowed father and mid life. Need to go fast. Really fast! This is not dead. Worked on them today. All the best.
  19. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Here it is!
    154,520Coins
    +11,184 / 57 / -2
    Your new ride looks super clean and original...that should satisfy the mid-life urges!
