3 DOF build (scn5 actuators) new project
Discussion in 'DIY Motion Simulator Projects' started by haroldjames, Dec 12, 2015.
  1. Blame73
    Blame73 Well-Known Member
    8,314Coins
    I would increase values in the tuning center for Extra1
  2. Nick Moxley
    What are your Tuning center #'s Also what game are you testing on
  3. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Here is a pic of the tuning center. The sim Im using is rfactor2. I have tried numbers from 1.0 to 170.0 in the tuning center with 1 set in the washout in the game engine. All other axis are disabled at the moment until i get the traction loss sorted out. With these setting i get very little movement out of that axis. If i put washout to "0" and set the smoothing to 50 % it is better but not realistic. TuningCenter.jpg
  4. Nick Moxley
    Do you have access to a Skid pad style track ? To watch the tuning center values while you turn and apply throttle, for the most part i match my Min/Max with the actual data for Extra1 , for example in Assetto my Extra 1 is @ 14 i believe which is a slide and catch moment for the most part, yes a Full 360 spin out might pull out a higher min/max but using the heave trick in running a really low min/max to speed up/access the data from the axis in question isn't a wise idea for Traction loss imo.....and 4.xx for Extra1 will result in sketchy motion....Why run any wash out, leave it all @ Zero , get it working properly, Then Start to tweek and tune as you feel needed.
    • Informative Informative x 3
  5. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    I dont have acess to a skid pad but i will try setting up with no washout and see how that goes.
  6. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Thanks for the help. I tried the number you used for extra 1 and it made a huge difference. I put 14 into the min/max and it was a lot more realistic. I also purchased assertto corsa last night so I will use that to dial in my sim. Once Im happy with it I will try setup my other sims. (rfactor2 and Pcars)
  7. Nick Moxley
    Glad you got it up and working Harold...>Any more Question's let us know.
  8. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    I just installed Assetto Corsa and patched the game. When the game manager is running it is green and when I start AC it goes blue for about 1 second then goes back to green. The game continues to run with no issue. Also unpatched and repatched, still the same. Has anyone come accross this problem? thx
  9. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Its ok, got it figured out. thx
  10. sliversgyj
    sliversgyj New Member
    - 27Coins
  11. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Here is a link to my finish project. This is the first time using youtube so i hope i did it right.
    153,890Coins
    +11,154 / 57 / -2
    You will need to change the YouTube permissions for this video to public so others can view it, at the moment they are private so it can't be viewed: https://support.google.com/youtube/answer/157177?hl=en
  13. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    ok, I believe I have changed the settings to public. In the video my grandson is driving and he spends a lot of time off the asphalt and in the grass. lol
  14. j0no5mith
    j0no5mith New Member
    214Coins
    great work! looks amazing
