newbie with some questions..
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Swets, May 6, 2008.
  1. Swets
    Swets Member
    PLC Programmeur
    Holland/Krimpen a/d IJssel
    375Coins
    I'm new here on this forum .
    so let me introduce myself:
    I'm Arjan Swets.... 40 years old (pfff) married with Karin, one Daughter.
    I work as PLC programmer.
    Hobbys: Robotics,electronics,programming,cnc
    more about me on my homepage: http://www.arjan-swets.com
    first my english is not very good, but i do my best...
    I bought on a Flea market a secondhand logitech wingman formula force GP , but without the adaptor...
    so i search internet, and i found it... and everthing works alright.
    but i also found this forum....
    and after reading for 4 evenings I have some questions about DIY motion simulation..
    because I think to build something....
    First what is the best system for car simulation? 2 DOF or 3 DOF? ( i know there is 6 dof too but i want to start not to difficult)
    and then 2 dof like this:
    (i have also see something like above, but with a 3 axle . see http://www.jimspage.co.nz/pictures.htm
    , is it than 3 dof?, and is this better?)
    or 2 dof like this:
    or 3 dof like this:
    or 3 dof like this:
    I think the last one... ?
    and now more questions....
    what do I need for software?
    works it with all simulation games? or games with DirectX.
    what cost the software?
    What do i need for electronics?
    eeehh here on the forum i see some ,where the monitor moving with the simulator, and some where is the monitor standing still in front of the simulator....
    i think it is better (?) when the monitor is moving with the simulator?
    i stop now, maybe i have more questions later....
  2. Swets
    Swets Member
    PLC Programmeur
    375Coins
    nobody? hmm
  3. tronicgr
    tronicgr
    Hi Arjan,
    Welcome, sorry that nobody replied back until now. We are busy building our simulators... 8)
    For car simulation its better to use 2DOF that is more simple to build.
    You can build something simple like this:
    tronic-s-full-motion-car-racing-simulator-using-x-sim-t471.html
    And my site with full instructions:
    http://ptyxiouxos.net/greekbotics/user_ ... ulator.htm
    OR build a SimforceGT type simulator:
    ego-s-simforcegt-with-dc-actuators-t547.html
    For electronics you can use those I mention on the above site, or build the new better ones that I describe here (DIY):
    tronic-s-amc-motor-motion-controller-with-pwm-servo-output-t559.html
    tronic-s-diy-dual-mosfet-h-bridge-t820.html
    For software you should use x-sim software located here:
    installer-x-sim-beta-1-6-9-t787.html
    The x-sim software is free!
    As you can see its all here, just a little search is needed! :thbup:
    Best Regards, Thanos
  4. Swets
    Swets Member
    PLC Programmeur
    375Coins
  5. tronicgr
    tronicgr
    Hi Arjan,
    Its your choice!
    Some prefer the SimforceGT type as its more simple. But it can be used only with car simulation games! Its advantages is that it can be used with projector screen as the screen in front of the driver stands still. And the footprint of the construction is a lot smaller, actually two DC motor actuator behind the seat!
    On the other hand the joyrider type can be also easily converted and used as Flight simulator! :fly: When I originally made this motorized joyrider sim I was using it only for flight simulation until I tried the x-sim software and realized the possibilities with car simulation! And the immersion, in my opinion, is much better since everything are following the cockpits motion (screen, steering wheel, pedals). BTW, I used simple car windscreen wiper motors to move it... Did you seen the videos?
    Regards, Thanos
  6. Cubane
    Cubane New Member
    Programmer
    Australia
    327Coins
    I would be interested to know how the motorised joyrider compares to something like Force Dynamics 301. Since it has that extra dimension of movement.
  7. tronicgr
    tronicgr
    No simulator that I know can compare with FD301 (or the more new FD401!!). Its a professional commercial simulator that costs $$$$$ after all!
    We are making just cheap home motion simulators here (yet).
    Regards, Thanos
  8. Swets
    Swets Member
    PLC Programmeur
    375Coins
    ehhh... Do the DIY simulators not move forwards if you press on the brake? ( for the g-forde feeling )?
    thats why I thought it is beter that the screen is moving with the machine ...
    because you see the horizon on the same place, so the movement feel as g-force....
  9. tronicgr
    tronicgr
    The SimforceGt does smaller angle motion and it doesn't affected too much from the stationary screen... It mostly simulates the stress on the hand muscles (when holding the wheel) during acceleration... It tricks the mind using body stimulus that combined with synchronized optical stimulus gives you the desired immersion.
    And its true that with the screen moving along the motion path the immersion its way better! And it gets even better if you fully enclose the cockpit to block all the external reference visual cues! I wish I had the courage to try enclose my joyrider cockpit too this way...
    Regards, Thanos
  10. Swets
    Swets Member
    PLC Programmeur
    375Coins
  11. tronicgr
    tronicgr
  12. Swets
    Swets Member
    PLC Programmeur
    375Coins
    to bad, the where cheap... :D
  13. Swets
    Swets Member
    PLC Programmeur
    375Coins
    so for 3 motors i need one tronic-s-amc-motor-motion-controller-with-pwm-servo-output-t559.html and two times tronic-s-diy-dual-mosfet-h-bridge-t820.html ?
  14. Swets
    Swets Member
    PLC Programmeur
    375Coins
  15. RaceRay
    Hamburg, Germany
    23,876Coins
    Hi Arjan,
    soory that we haven´t answered your question, yet. I think your thread is overlooked everytime, because your title of your thread isn´t very precise ;) Better you rename it in something like swets DIY 3DOF simulator - the beginning
    Maybe, it makes other users curious and increase the chances to get an answer.
    Later you can use that thread to describe your whole project status ... with many pictures and videos, please :D
    BtTopic: Yes, thats right. This compilation is designed to work perfectly together. The motors are dependable of your platform design.
    I know that 10A current is safe for the H-Bridge, but i don´t know the maximum currents with massive cooling for Thanos H-Bridge. So you should ask him, if you decide to use larger motors than car whiper motors for your 3DOF platform. When your platform is work in progress and there are some serious results you also have to ask him for a modified 3DOF firmware.
    Kind regards
    René
    B.t.w. i like swets 3D :D
  16. Swets
    Swets Member
    PLC Programmeur
    375Coins
    and the hexfile for the avr?... can i download it ...or buy it?
  17. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    The hex (firmware) is free. Have a look at the corresponding thread. You will find all you need at the starting post.
    As well this thread is the proper place to ask about the controller.
    Regards
    Christian
  18. Swets
    Swets Member
    PLC Programmeur
    375Coins
