Arduino UNO R3 external power
Discussion in 'Electronic and hardware generally' started by mimakez, Feb 3, 2016.
  1. mimakez
    mimakez Member
    263Coins
    Sometimes it happens that the Arduino silenced and simulator are no more moves. in this case I have to disconnect the USB cable and re-pinned, restart the computer and everything works again. I use a USB cable 5m length for power Arduino and data. Would it be better to put an 12v externally power the Arduino?
  2. SilentChill
    20,601Coins
    Is it not a 5v power you need not 12v ?
    I use a sepeartly powered 10 port USB hub.
  3. mimakez
    mimakez Member
    263Coins
    I put external power supply for Arduino 7.5v and so far everything is OK, we will see in the coming days whether to fix the problem with silenced Arduino
    Thx for your replay
  4. Historiker
    9,205Coins
    It might be that your motors are moving outside the set parameters in your arduino sketch. This would cause the arduino to stop sending positional information until it is rebooted. Check the documentation of the sketch that you are using.
  5. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    The arduino has an external power supply connector which can accept 12V DC. 5v is then sourced from a regulator.
  6. meo_udon
    meo_udon New Member
    691Coins
    Long cable, please use double shields USB cable.
  7. mariana fino
    mariana fino
    I had the same issue ,i change my usb port a solved but check your power saving options ,and your pc bios so the usb port dont disconect !hope you solve your problem! my arduino its just power by usb with a 3 meters usb cable and no problem!
