Simulator TJC Superman
Discussion in 'DIY Motion Simulator Projects' started by cedric087, Jan 27, 2016.
  1. cedric087
    cedric087 New Member
    limoges
    232Coins
    Hello everyone.
    Finally ... I throw myself into the creation of my 2DOF simulator prototype to begin with to hopefully eventually evolve.
    For now, the creation of the base through one of the masters of this place Wanegain course.
    As salvaged wood, scrap metal, seat ....
    Purchase at this time: Alim 2x20A, 2x32A Saber Tooth, Arduino Uno, 2 Valeo same reference heavy duty engines that Bebert on which I will take the idea of the knob
    http://www.xsimulator.net/community/attachments/20160123_181309-copier-jpg.28000/
    http://www.xsimulator.net/community/attachments/20160123_181319-copier-jpg.28001/
    http://www.xsimulator.net/community/attachments/20160110_110921-jpg.28003/
    http://www.xsimulator.net/community/attachments/20160113_221611-copier-jpg.28005/
    http://www.xsimulator.net/community/attachments/20160117_174600-copier-jpg.28006/
  2. cedric087
    limoges
    232Coins
  3. Wanegain
    Wanegain Active Member
    Bruxelles
    2,003Coins
    Very good !
  4. cedric087
    limoges
    232Coins
    20160128_221331 (Copier).jpg Progression in my simulator, pose potentiometers.
  5. Pit
    30,490Coins
    could be a short circuit once upon a time:
    • Agree Agree x 5
  6. Wanegain
    Bruxelles
    2,003Coins
    Yes he's right maybe you can use heat shrink sheating (en français de la gaine thermorétractable), but you should think before welding :D
  7. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    Also you should really think about re-soldering those connections, butt joints like that will fail after flexing.
    Pin soldering should have the wire hooked around the terminal like so:
    I must admit I have definitely soldered connections like that for a "rush" job but nothing permanent. Pit is definitely right about a good potential for a short across those two pins.
    151,991Coins
    +11,061 / 56 / -2
