value1
Need For Speed Plugin 0.0.0.0
SimTools game plugin for Need for Speed Series
  1. noorbeast
    153,770Coins
    +11,149 / 57 / -2
    Try running the Game Manager as Administrator @Raulmerlos.
  2. Raulmerlos
    Raulmerlos Member
    Mecanico maquinaria calzado
    Monóvar (Alicante) España
    138Coins
    3DOF, Arduino
    Ok, Solved, thanks.
  3. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    Hi Guys,
    Trying to patch NFS Shift 2 Unleashed and tried all combinations (Run as Admin etc) and I keep getting the "wow64ext.dll" install error, however the plugin does not contain a wow64ext.dll file in the Zip, just the Plugin Title .dll file.
    I am clearly missing something obvious? :)
    systems is Windows 8.1 64bit. NFS Shift 2 is the Steam Version. (32bit Version)
    Plugin (when unzipped)
    Attempt to patch and the path:
    The error:
    Thanks in advance :)
    Archie.
  4. value1
    14,237Coins
  5. Archie
    Wollongong, NSW, AU
    3,797Coins
    Thanks @value1 - Talk about "customer service!" :) - I jumped ahead and already made a Zip file with the wow64ext.dll file from the NoLimitsPlugin, however still no joy.
    (and also just tried with your updated plugin)
    I did notice, unlike other plugins the prompt says "Locate your simtools" directory when patching. What is the path for it? Could you provide an example of the folder content so I know I'm looking at the right spot?
  6. value1
    14,237Coins
  7. value1
    14,237Coins
    It's like C:\Program Files (x86)\SimTools
  8. Archie
    Wollongong, NSW, AU
    3,797Coins
    Thanks @value1 - Managed to resolve it. I had put Simtools on G:\Program Files(x86) (My steam drive) rather than the default C:\Program Files(x86)
    Once I backed up my AppData, removed Simtools and re-installed to C:\ and restored my settings all is good now.
    I had to manually copy wow64ext.dll to C:\Program Files(x86) still, but I suspect it's my PC rather than a common issue.
    Thank you so much, sorry for causing you more work than was needed :oops:
  9. value1
    14,237Coins
    Welcome. And no problem. I knew that at some point I had to add the wow64ext.dll to the plugin. And I removed an error from the Rivals module ;)
  10. Boomslangnz
    4,172Coins
    Ive managed to get a few of the NFS games over last couple weeks, I haven't actually tried the plugins yet but will do over the next few days. Just a heads up that NFS Rivals actually has no support at all for wheels and NFS Most Wanted 2012 supports wheels but has no force feedback at all (pretty poor really in this day and age)
    Couple games I wish I didn't bother purchasing (should of done some more research)
  11. bsft
    Consider it an investment for later
  12. Asif Habib
    Asif Habib New Member
    Engineer
    Pakistan
    74Coins
    2DOF, 3DOF, Motion platform
    The updated plugin does not work with Need for Speed Most Wanted with Patch v1.3.
    Can anybody provide me a download link for the NFSMW with the version that the given plugin supports???
  13. DaVinster
    DaVinster Active Member
    What does I.T. stand for?
    AB, Canaduh
    1,150Coins
    3DOF, SCN6, Motion platform
    Is the any chance this would work with NFS: Prostreet? On sale for $4 on origin this week.
  14. value1
    14,237Coins
    Funny enough I own both games, ProStreet and Undercover but did not include them in the plugin :(
  15. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    I tried NFS most wanted(2012). EA origin version. now on free!!. I did patch in simtools installation directory but no motion. I can see game running NFS series, but no data in tuning center. what can I try?? help me~~
  16. noorbeast
    153,770Coins
    +11,149 / 57 / -2
    I have not tried it but did you try patching running GameManager as Admin?
  17. hb kim
    hb kim Member
    incheon, korea
    602Coins
    2DOF, SCN5
    of course, I got the error writing wow64 dll?? so I did it as admin and different from other games, installation directory is simtools location rather than game directory. hope you have an idea, thanks in advance...
  18. Archie
    Wollongong, NSW, AU
    3,797Coins
    I had the same issues with NFS Shift Unleashed. I've never revisited it to be honest but will hopefully get time this weekend to also try NFS Most Wanted.
    Will report back to this thread if yes or no for motion.
  19. Archie
    Wollongong, NSW, AU
    3,797Coins
    Not had time to test this yet. But adding a comment to remind me!
  20. Archie
    Wollongong, NSW, AU
    3,797Coins
    Finally tested this and no matter what I do, I can't get any motion from this plugin. No values in the Tuning centre.
    Game Engine is turning blue, but that's it.
    Shame as NFS:MW is actually fun to run around in.
    I also had no luck with this plugin on NFS:Shift2. :(
