Request (Feature) Plugin for Lunar Flight
Discussion in 'SimTools Plugins' started by DaVinster, Jan 26, 2016.
  1. DaVinster
    DaVinster Active Member
    What does I.T. stand for?
    AB, Canaduh
    1,150Coins
    3DOF, SCN6, Motion platform
    This is a marvellous VR experience and just screams for motion! Works very well with a DK2. Other HMDs being supported soon.
    Any chance of a plug-in for this simulator?
    http://store.steampowered.com/app/208600/
    TIA!
    DaVinster
    153,770Coins
    +11,150 / 57 / -2
  3. DaVinster
    AB, Canaduh
    1,150Coins
    Thanks Norbeast.. I will do.
    Cheers!
    DaV
  4. darkcrayon
    darkcrayon Member
    New York, NY
    305Coins
    3DOF, SCN5, 6DOF
    I took a look at this, I've never made a plugin before, that direct memory access is even more complicated than I thought (after the initial steps to find the current memory location of the game variables) :) It might be one of the easier games to make one for though, since it looks a lot of the motion variables are even displayed by the game itself. e.g. velocity, pitch, yaw, etc.
  5. DaVinster
    AB, Canaduh
    1,150Coins
    Well thanks for looking into it darkcrayon :thumbs
  6. BlazinH
    16,689Coins
    The problem with actual pitch, roll, and yaw data though is once you are in a zero gravity environment they are useless for motion. You need to use inertial velocities instead but you may be able to calculate them from the pitch, roll and yaw data if they can’t be found.
  7. darkcrayon
    darkcrayon Member
    New York, NY
    305Coins
    3DOF, SCN5, 6DOF
    You probably understand this general concept better than I, but in this game it isn't zero gravity, just less gravity (you're flying around over the moon).
    The game actually uses your velocity, or at least vertical velocity, as one of the visible stats along with pitch, roll, and yaw. I guess since it's a vacuum, the only thing that can alter your pitch, roll, and yaw speed aside from your thrusters is if you bounce off of an object :)
  8. DaVinster
    AB, Canaduh
    1,150Coins
    I think I would be ok with just the roll pitch and yaw since your eyes play a large roll (if you will :p) in sensing speed with motion.
    In this case I'd be ok with feeling the direction the lander is leaning, not necessarily for motion cues. You're generally moving very slow anyway. The feeling and visual that the lander is pitching too far back would be pretty cool, and a little unnerving :)
