parametric objects and openscad
Discussion in '3D Printing' started by bruce stephen, Feb 13, 2016.
  1. bruce stephen
    general contractor
    michigan
    9,115Coins
    20160213_120052.jpg Parametric objects amongst other things are models based on parameters. What does this mean to the end user? it basically means you can take an object and change aspects without redesigning the whole object. For instance you could adjust the size of a parametric object just by replacing some numbers in the code. Although there are many design programs out there I prefer openscad. It is also a free app. Openscad will export .stl files for you to run through your slicer of choice.
    this is a parametric file for an enclosure http://www.thingiverse.com/thing:539213/#files
    and this is where to get openscad http://www.openscad.org/
    there are a ton of parametric objects available to dload and print.
  2. bruce stephen
    general contractor
    michigan
    9,115Coins
    same box as above
  3. bruce stephen
    general contractor
    michigan
    9,115Coins
  4. insanegr
    insanegr !N$@n€
    Athens
    16,725Coins
  5. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    Gear generator.
    Outputs many different types of 3d models. however if you require STL then you need to import/convert.
    http://www.rushgears.com/
    You can adjust gear pitch, tooth count, hubs, counter bores, keyway, grub screw and backlash.
