Greg's journey into the world of 2DOF simulators
Discussion in 'DIY Motion Simulator Projects' started by Greg83, Feb 17, 2015.
  1. noorbeast
    151,467Coins
    +11,039 / 56 / -2
    It always helps to post screenshots of all your settings, and to do that on your own thread.
  2. insanegr
    insanegr !N$@n€
    Athens
    16,721Coins
    @kimballfount it could be for some reasons. without any screen shots from your settings it could be hard to find out. . open a new thread describing your problem with some shots so we can help more.
  3. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    Will do, thanks
  4. kimballfount
    kimballfount Member
    greer,sc
    879Coins
    I just had to run it Game Manager as Administer, works now
  5. Greg83
    Greg83 Active Member
    IT Specialist
    Budapest, Hungary
    328Coins
    So been really busy with fine tuning, here is the result:
    There is a small lag on the video between the seat moving and AC, but that is only due to editing...
    My current settings:
    Although I might have still have errors as just checked and my game manager does not have exactly these settings...
    Project will now probably sleep two weeks as ski holiday is coming up, but getting there!
    Even though this project is not finished, already the two new projects are being put together in my head :D
    H shifter by @Scratch : http://www.xsimulator.net/community...f-crate-racing-cockpit.5446/page-7#post-70090
    And later upgrade to worm drive motor and server psu maybe :)
  6. Blame73
    Blame73 Well-Known Member
    8,303Coins
    Because of the lag I'm not sure, but sway seems to be inverted. On right corners it should lean to the left (as opposite as motorbikes do) to simulate the forces.
  7. Greg83
    IT Specialist
    Budapest, Hungary
    328Coins
    @Blame73 : Are you sure? @0:50 you can see that first it throws me to the right (bumps on the left) and then throws me to the left (bumps on the right).
  8. Blame73
    8,303Coins
    No, I'm not sure. The asynchronous video doesn't help...
    Anyway who better than you could say it?
    151,467Coins
    +11,039 / 56 / -2
    You have plenty of heave set in SimTools but there does not seem to be a lot of heave effect over things like ripple strips and the Monzs straight. Monza in AC actually has a lot of surface detail that you may be missing out on, though the camera on the rig is pretty far way so it is hard to tell.
    Try lowering the values in the Tuning Center for heave and test it out.
  10. choclo
    choclo Member
    Vienna
    388Coins
  11. Greg83
    IT Specialist
    Budapest, Hungary
    328Coins
    Hey,
    As I have a Skoda Octavia I ended up with two replacement Febi for that.
    It has more than enough power, it just gets a bit hot as this is not the basic design for its use :D
