0-10 VDC Output form X-Sim
Discussion in 'SimTools compatible interfaces' started by Imaginex, Apr 22, 2009.
  1. Imaginex
    Imaginex New Member
    London, Canada
    Hi - I've been following the X-Sim site/software for quite a while - with some background in animatronic/motion display projects, I decided earlier this year to tackle a relatively low cost 3 DOF pneumatic 2 seat motion base utilizing proportionally controlled directional valves.
    Nearing the end of frame construction and shifting focus to actuators/control system -
    Can anyone suggest best method re. hardware for outputting 0-10 VDC command signals from X-Sim?
    My strength isn't in circuit board construction so I'll have to pass on Tronic's diy stamp motion controller - which I believe does output 0-10 VDC. I see that Velleman has an extended USB interface board VM140 that has 8 x 0-10 analog outputs http://www.vellemanusa.com/us/enu/produ ... ?id=523886
    - is this compatible with X-Sim?
    the valves have their own closed loop control circuitry/driver so they are only looking for 0-10 VDC command signal i.e. 0 VDC full retraction, 5 VDC mid stroke, 10 VDC full extension
    thanks much!
  2. tronicgr
    tronicgr
    Hi Imaginex,
    Since your valves has their own closed loop control circuitry/driver, you could use the VM140 to feed them with the necessary analog values. But I'm not sure if VM140 is supported by x-sim software. Never heard of it before used here.
    In worst case you could use two common VM110 boards with a simple to make PWM to analog voltage converter, like the one I present on the following link:
    post14488.html#p14488
    Good luck with the pneumatics... You going to need it!!! :brows:
    Regards, Thanos
  3. Imaginex
    Imaginex New Member
    London, Canada
    thanks for the feedback Thanos
    yeh - I only decided on pneumatic actuators as I have access to very fast servo type directional valves with high flow rates.
    looking at a recent post from SirNoName I'm hopeful a plug-in for the Velleman VM-140 will be implemented in the near future - which would be a very simple and affordable method for outputting 0-10 VDC commands - although they are only 8 bit
    in the meantime, for members in need of different control outputs, here are some other fairly low cost and simple solutions that might be worth considering:
    http://www.controlsignalconverter.com
    http://www.bpesolutions.com/rcequip.html#anchor142875
    http://www.kele.com/webservices/index/i ... ?section=9
    Regards
  4. lysa elec
    lysa elec LYSA ELEC
    - 26Coins
    Has you it a plugin for the compatible card K8061 / VM140 with X SIM
    there this card seems to me enough good
    thanks
