1st 2DOF compact build attempt
Discussion in 'DIY Motion Simulator Projects' started by maligator, Nov 18, 2014.
  1. maligator
    maligator New Member
    228Coins
    So, first off, thanks to all of you for this great resource! I previously never thought it would be possible to get into a motion rig of my own for less than an arm and a leg. I have a small MIG welder and know how to solder so hopefully this goes good.
    My goal is to modify the wooden static racing rig I have built with a 2DOF setup that will not significantly increase the footprint of the current rig. I think to do this I will design similar to the desk racer rig that I have seen on this form. That was just excellent! So, this will mean front mount motors which I know are not ideal but it should work I hope. I do not want a rig that is going to toss me around like a rag doll. I simply want decent, accurate feedback of g forces to help me feel what the car is doing and increase the immersion. I play mostly iRacing so no rally car bouncing around is needed.
    Here is how the rig sits now, minus my nephew racing and the triple screens since I have gone to rift only racing now.
    The seat is from a wrecked Mitsubishi Eclipse and might have to be replaced with a decent (cheap) racing seat. For one, it is heavy and two I will probably want a 4pt harness which this will not accommodate.
    I am wondering if it is possible to use simtools on the same computer that I race with. I really do not like the idea of having to have a second PC just for that (space concerns and hassle).
    So far here is what I think I will need (I am sure there is more I will find out or remember as I go). Please feel free to comment on my choices or offer alternatives.
    MotoMonster
    2x 360* pots
    HP server Power supply
    2x crab pot motors (http://www.ebay.com/itm/GEAR-MOTOR-...384?pt=LH_DefaultDomain_0&hash=item51bd392f00)
    1x U-joint from a 300zx drive shaft (already had one)
    Self made brackets, frame etc
    Many switches and 12v fans etc
    As I noted, I am not sure of what kind of power supply(s) to get. I would like to get away with one to save space and I like the idea of those used server PSUs. Any suggestions?
    Thanks in advance and I will post pics, amount spent and progress updates as I go.
    UPDATED 11/18/14:
    Purchased:
    2x HP 575w Server PSUs $25
    Total Spend so far: $25
  2. bsft
    Hello there, good stuff on the list of parts.
    Nothing wrong with desk racer set up for seat mover, thats why I built it. it will not throw you around too much. Motors at the front like that work just fine.
    Yes replace the seat with a lighter one for sure.
    As for power supplies, yes, the server ones are popular, @Nick Moxley has a wiring diagram I think.
    Here in Australia, unfortunately everything is expensive, even server PSU, so I use 2 , 12v 40 amp LED psu bought off ebay.
    For computers, as long as its 4 core CPU, min 4 gig ram, you will be fine running Simtools and game. I run the desk racer off a cheap built AMD quad core PC. Its the graphics card that cost the most in individual component costs to get decent graphics on a single screen.
    Have fun building.
    Dave.
    148,886Coins
    +10,922 / 54 / -2
  4. maligator
    228Coins
    Thanks Dave. My gaming rig is an FX8350 8 core and has 16gig RAM so hopefully will be fine.
    Am I correct to say that I need 15amp supply for each motor? I calculated that from the 180w rating at 12v. Would I be OK with a 30 amp power supply for each side? I found these and like them better than the server supplies.
  5. maligator
    228Coins
    Thanks! It will be a seat shaker only and I hope to have the mounts to the front of the seat so I can keep a small footprint. Trying to keep the wife happy.
    148,886Coins
    +10,922 / 54 / -2
    Great way to go @mailgator, I did the same thing using @bsft's Desk Racer for inspiration but expanded it to be used in multiple modes.
  7. Nick Moxley
    17,056Coins
    More like 40Amp Minimum for each motor. The 600pb's have been ROCK solid. Plus they are Dirt cheap compared to the Ebay LED supplies. Where are you located ?
  8. maligator
    228Coins
    I am in MA. Can you recommend any specific PSU? Why 40amp per if the motor is only rated 80 watts? Thanks!
  9. Nick Moxley
    17,056Coins
  10. maligator
    228Coins
    148,886Coins
    +10,922 / 54 / -2
    DC motors will have serious power spikes when pushed hard in a motion sim, you need to leave plenty of PSU overhead for them.
  12. maligator
    228Coins
    It's settled then, I guess I will order 2x HP server supplies!
  13. noorbeast
    148,886Coins
    +10,922 / 54 / -2
    The HP PSUs are very cheap on Ebay, like $20, and the mod @Slider detailed is actually pretty simple. Cheap enough to even consider grabbing an extra one for a spare.
  14. maligator
    228Coins
    Yes, they are quite cheap! Bonus. I am making a spreadsheet of all the parts I will need. I just wish I could find a cheaper source of those crab motors as they are the most expensive items so far. Also need to find a cheap but comfortable racing seat.
    I just read @Slider's tutorial, looks very simple!
  15. noorbeast
    148,886Coins
    +10,922 / 54 / -2
    Where in the world are you located...shipping is often the killer cost with DC motors.
  16. maligator
    228Coins
    I am in USA. The ones on ebay are shipped from Canada so only $16 shipping but that still brings the price to about $106 each. It would have been nice to get away with some junk yard wiper units or something half the price at least. I am sure in the end it will be worth it for the new motors (hope).
  17. noorbeast
    148,886Coins
    +10,922 / 54 / -2
    You could use wiper motors and they are cheap but I think for a Desk Racer type of design you are better investing in the crab pot motors.
    If you stick with the desk racer design 25:1 will work fine, just check out some of the videos @bsft has done. If you do a modified version and mount heavy controllers on the sim like I did then 50:1 is needed. You can get the crab pot motors with 50:1 gearboxes for the same price: http://www.ebay.com/itm/GEAR-MOTOR-...483?pt=LH_DefaultDomain_0&hash=item51bed470a3
  18. maligator
    228Coins
  19. bsft
  20. maligator
    228Coins
    Oh man. It appears I have! I doubt the seller will cancel but I will have to ask. WTF!!!
