24V motors not running
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by jarena, Mar 28, 2024.
  1. jarena
    jarena Member Gold Contributor
    126Coins
    Hi guys,
    So without the motors connect I can see in SMC3 that if I move the POT left or right the green line will go up or down. when I follow the the steps of the tutorial for Arduino step five i set everything at 0 then i got step 6 and set the values and I see the lines setting them selves and the positions they should be. then I plug the motor 1 and nothing should which is the case. i set the kp at 400, and slowly increase the PWMAX but nothing is moving from motor 1, I did the same thing with motor 2 and same result. what am i doing wrong?
  2. Trent Robinson
    Trent Robinson Member
    Systems Engineer
    288Coins
    Hard telling from just this. Screen shots of your settings is a good start and pictures of the wiring might help. You could check with a multimeter at the motor to see if any voltage is present.
    147,464Coins
    +10,865 / 54 / -2
    Is the pot connected to the motor?
  4. jarena
    126Coins
    yes they connected to the motor, recheck all my wires and check the continuity and all check outs
    147,464Coins
    +10,865 / 54 / -2
    In that case please post pictures of all of your settings and wiring.
