2DOF build.
Discussion in 'DIY Motion Simulator Projects' started by Turbo_Tim, Mar 5, 2024.
  1. Turbo_Tim
    Turbo_Tim New Member
    - 4Coins
    Hello, I have been following along for a while and I am going to start my first build. I have been collecting parts and I think I am close to having everything.
    So far I have the following:
    • 2 Jazzy Electric motors (120rpm at 24)
    • 2 480 watt power converters
    • ARDUINO R3 with ElectroCookie
    • 2 JiLegogo bts7960 Motor drivers
    • flanged u-joint
    I still need to pick up the Hall Effect Potentiometers and tie rods ends but am I missing anything else.
    Where do I find the keyway arm to connect to the motor? Is that a DIY or is there somewhere I can find it with the keyway already cut into it? If it is a DIY what length would I want for this motor to ensure the appropriate torque?
    Does mounting the motor at the front or back of the rig make a big difference?
    Thanks.
    154,274Coins
    +11,177 / 57 / -2
