2dof convert 3dof ?
Discussion in 'DIY Motion Simulator Projects' started by josemanuelrm26, Nov 8, 2015.
  1. josemanuelrm26
    josemanuelrm26 my 2dof
    valencia
    - 13Coins
    Hello
    I have a question I'm actually thinking of doing
    2dof and have a monster and Arduino, 2 engines and if to make a 3DOF
    What I need ?
    With Arduino'd rather guess I'd have to buy another monster but as would connect wiring?
    Thank you
    Hola
    Tengo una duda que estoy pensando en hacer realidad
    Tengo un 2dof y con arduino y monster, 2 motores y si quisiera hacer un 3dof
    que necesito ?
    Con la arduino tendria bastante supongo que tendria que comprar otra monster pero los cableados como se conectaria ?
    gracias
  2. Pit
    30,451Coins
    Hi you can't build a 3DOF by using only 2 motors.....
  3. josemanuelrm26
    valencia
    - 13Coins
    if it would add another engine for the behind
  4. Pit
    30,451Coins
    a 3DOF is already a tricky concept, you need very strong motors or an additional spring. Please share your specs of your hardware.
  5. bsft
    3 dof lift or 3 dof drift?
    • Agree Agree x 4
  6. Pit
    30,451Coins
    Very good question :)
  7. josemanuelrm26
    valencia
    - 13Coins
    is for when cornering go back skidding car.
    I imagine drift. I have the simulator with front engines
    and this third party would put behind
  8. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Check @Pit 's tutorial http://www.xsimulator.net/community...cts-as-a-single-motor-driver-more-power.5482/
    SMC3 code can access up to 3 motors using one Arduino. If you want to connect 3 MM please wire described as follows:
    Arduino -------- Monster Moto
    2 (Motor 1 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    3 (Motor 1 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    9 (Motor 1 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    Arduino -------- Monster Moto 2
    4 (Motor 2 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    5 (Motor 2 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    10 (Motor 2 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    Arduino -------- Monster Moto 3
    6 (Motor 1 H-Bridge ENA) ---------------7 and 8 (INA1 and INB1)
    7 (Motor 1 H-Bridge ENB)----------------4 and 9 (INA2 and INB2)
    11 (Motor 1 PWM) --------------------------5 and 6 (PWM1 and PWM2)
    Read the rest...
    EDIT: Mmm, you want to use 1 MM for two motors and another one for drift, better ask @Pit
    I'm using two MM for two motors and works great.
  9. josemanuelrm26
    valencia
    - 13Coins
    Thank nonster then another and another motor would have already mounted.
    I will ask for a monster to begin.
    Thank you
  10. bsft
    copy that, 2 DOF balanced pivot, with 3rd DOF drift frame.
  11. mariano68
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Ops, no me di cuenta que hablamos el mismo idioma, te lo hago mas sencillo, podes usar una motomonster para cada motor y una sola "Arduino UNO" para las tres por ejemplo. No se como sera la coneccion si queres usar una motomonster para dos motores y una mas para manejar un motor extra, pero no debe ser ninguna ciencia oculta.
    Just translated my last post.
  12. josemanuelrm26
    valencia
    - 13Coins
    Siii hablando español me aclaro mas. gracias eso voy a hacer 1 mosterv para motores delanteros y otra para el derrape.
    Spanish speaking Sii me clarify more. because that will make 1 mosterv engines for front and one for the skid.
