2DOF+Thanos4U
Discussion in 'New users start here - FAQ' started by NIKOLAS TSAKRIS, May 18, 2024.
  1. NIKOLAS TSAKRIS
    NIKOLAS TSAKRIS New Member
    22Coins
    Hi guys, totally new member and first post here. I just need some basic questions answered in order to start and I will try to do the rest of the reading required.
    So I want to setup a 2DOF (pitch and roll) using 2 SFX actuators at the back and just 1 pivot point (no actuator just a joint) at the front. I have a Thanos4U controller. Does simtools work with Thanos4U(this is the 4 port version, not the AMC version with the 7 ports) to implement this configuration? Will it need to work in parallel with other software like FlyPT?
    I had back lack buying the SRS license as I found out that they only support a minimum of 3 actuators configurations (2 Back+1 Front or 1 Back+2 Front)
    I will appreciate any help.
    147,009Coins
    +10,845 / 53 / -2
    Yes if properly configured it will work with SimTools as a 2DOF. FlyPT is not needed in parallel.
  3. NIKOLAS TSAKRIS
    22Coins
    Thanks a lot mate for taking the time to answer this.
