3DOF with AC drives
Discussion in 'DIY Motion Simulator Projects' started by tanito90, Jun 1, 2018.
  1. tanito90
    tanito90 New Member
    Argentina
    139Coins
    3DOF, AC motor, Arduino
    Hello everyone, i will be starting a project in 2 months and i am going through the design phase right now
    The hardware chosen would be: 3 1.1Kw Ac 3-phase drives, with gear reduction or chain driven with encoders, 3 VFDs, and 1 arduino board.
    Before someone says something about using AC drives: I have no choice, nearly no access to DC drives in my country, and a 200w nema 42 cost U$S900 vs a U$S500 combo (1500w ac drive + VFD). And i have plenty of experience with AC drives and VFD considering i am an automation technician and designer, so i am not afraid of them.
    So first of all, i want the sim to be as realistic as possible regarding the G forces, and for that i would need a long stroke and therefore a good acceleration. I was thinking of 0.7m/s (for what i've read it is a nice speed and it's not crazy to achieve with selected setup)
    Also, i was having the idea of replacing the gear reductions for Sprockets, what do you think of that? A fixed sprocket with motorcycle chain, they are inexpensive compared to the price of a reduction box (U$S300 vs U$S50). It also allows you to fine tune the ratios to find the most suitable for the application.
    DESIGN:
    I still can't decide myself on the design, here i left you a design i thinked of 5 years ago, which i rendered to simulate the motion in video, but i want to hear your thoughts about it about the central fork/spring, do you thin it will be needed to dampen the movements? or i should just make it aerieal? It will allow me to distribute the weight to a central point and allow the drives to move more freely without having to support all the weight.
    IF i want to make it aerial, according to my calculations it would weight more or less 120/130kg with driver. That distributed in 3 points would make 42kg, and a Force of 411N per pivot point. If i use a 30cm lever that would make a 123Nm Force needed just to hold it in place.
    if EFy= m.a ---- 40Kg x 0,7m/s2 = Fn(force needed) - Fw (weight Force).
    28N = Fn - 411Nm ------ Fn= 439Nm x 0,3cm = 131Nm
    My current engines have an 8 pole config, which means 800rpm at 60hz, and they have 18nm at that rpms, i would need them to run @20rpm with a lever of 30cm to move at 0,7m/s, which means that the ending torque would be: 720nm.
    What do you think? i could make it even faster but this are just my first calculations, i don't know if i am doing something wrong.
    Thank you very much
    153,001Coins
    +11,116 / 56 / -2
    Just so you know the video is unavailable, perhaps check the settings on Youtube.
    150-700mm/s is a good speed zone to aim for in producing good motion.
    However when it comes to actual G-Forces a motion sim aims to fool your brain rather than replicate actual G-Forces. A traditional motion sim will likely only produce momentary force of around 2Gs to fool your brain, not the actual sustained 5-10Gs of an F1 car or fighter jet.
    So if G-Force simulation is your priority do some research on G-Seats and G-Force simulation systems that the likes of @SeatTime and others have been experimenting with:
    https://www.xsimulator.net/community/threads/seattimes-sims.11757/#post-152436
    https://www.xsimulator.net/community/threads/harness-tensioner.11911/#post-156464
    https://www.xsimulator.net/community/threads/building-a-better-mouse-trap.11739/
  3. tanito90
    tanito90 New Member
    Argentina
    139Coins
    Well that's great, didn't know about that kind of simulation.
    I've also solved the youtube privacy settings, so now you should be able to see the video.
    Yeah i know it's not possible to simulate the actual G forces, i've wrongly expressed myself. I want it to be as realistic as possible with the options i have chosen (3dof, 720nm torque at shaft @20rpm).
    Thank you
