6-DOF Stewart Platform to be controlled in one month!!
Discussion in 'DIY Motion Simulator Projects' started by aliaero, Jun 21, 2010.
  1. aliaero
    aliaero New Member
    Pakistan
    277Coins
    Hello guys,
    i am a huge fan of x-simulator software and i know this software for about 6 months or so and now i have decided to built a simulator for me too and this time it will be 6dof :clap:
    I have already built a stewart platform with my own actuators having DC Motors from the power windows of the car. i,ll be posting the pics shortly.
    i want to design the electronics for my self with the help of a friend.
    now i want some serious help from this community to run it as i want to accomplish this task in just one month to exhibit in a local science fair.
    i want to use MS flight simulator for the inputs, now can anybody help me how to calibrate this data in force profiler and what should be the first step to be done in Force profiler software. :sos:
    regards
    Ali
  2. Frakk
    Frakk Active Member
    328Coins
    Hi Ali,
    Have you worked out the geometrical calculations for the platform?
    It would be helpful if you described what you have so far.
    Do you have motor drivers? Do you have any experience in electronics? Microcontrollers?
    A month isn't going to be enough unless you have most of the design worked out.
  3. aliaero
    aliaero New Member
    Pakistan
    277Coins
    Our platform has been manufactured according to the required geometry of the platform.
    As far as Electronics is concerned we are building DC motor controller electronics using IRF450 Transistors as our DC motor runs on 4Amps and L298 cannot be used to drive such motor.
  4. aliaero
    aliaero New Member
    Pakistan
    277Coins
    Here is the first image of my platform that i want to control with x-sim software :)
    Any suggestions are more than welcome
    if having problems with image check it out here
    http://www.imgzzz.com/pic/1277147651
  5. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    437Coins
    This is a nice and economical solution for aircraft. Good job so far!
  6. aliaero
    aliaero New Member
    Pakistan
    277Coins
    Thanks a lot, Mr. Niels(Nima) will be helping us in the x-sim part!
  7. egoexpress
    I am looking forward to see some video footage.
    Great job so far!
    I hope the wiper-motors are strong enough to handle at least 1 person.
    Regards
  8. aliaero
    aliaero New Member
    Pakistan
    277Coins
    I hope so but our main concern is to just interface it with the software and run it in real time.
    what electronics would you suggest for interfacing it with the computer.
    As the motors are DC!
  9. egoexpress
    Tronicgr' AMC motion controller + Hbridge.
    But 1 set is just capable of controlling 2 motors, so you'd need 3 sets of AMC and Hbridge.
    Regards
  10. aliaero
    aliaero New Member
    Pakistan
    277Coins
    it will not be available at ours side so can i have the diagram of the circuit so that i can built it by my self with all the components! :)
    regards
  11. RaceRay
    23,862Coins
  12. Frakk
    Frakk Active Member
    328Coins
    The platform looks impressive for what it is, but I wouldn't put too much weight on it because of the motors. :)
    If your friend can design the electronics in about two weeks, you might have a chance to make it to your science fare. It is going to get very expensive if you build 3x AMC + 3x dual H-bridge, and you still haven't solved the geometrical calculations.
    Very cool project and I think it is time more people attempt the steward platform! Even if it is on a small scale, getting it working is already most of the work.
  13. CXCSimulations
    CXCSimulations Member
    - 9Coins
    Interesting..... I've always wondered if 6 150mm SCN6's would be enough power for a floater design like this. I realize this might be expensive for this project, but it does sound like it might hold enough weight.
  14. aliaero
    aliaero New Member
    Pakistan
    277Coins
    Thanks to all of you for taking interest in our project.
    We are also working on the Mechanical model Built with Simmechanics which is already provided inside of Matlab. These days we are also trying to design the PID controller to do some Rapid prototyping using xPC Target toolbox.
    For Matlab.....
    What i am really exited to know that How should we have to convert The Force values generated by The PID controller to the calibrated PWM voltage signal to send it to the National Instruments DAQ card. Any one have info about it, Plz help us.
    Finally @sirnoname
    Thanks for your useful info but can you plz explain that why cant we use The standard Math Interface as i have seen some videos of Stewart Platform running completly on the standard software.
    Regards
    Ali
  15. Frakk
    Frakk Active Member
    328Coins
    The standard math plugin takes a single effect, do whatever you need to do to make it work, then output this single axis to the output plugin.
    With a steward platform it is a completely different story. One game effect (Pitch for ex) has to move ALL 6 OUTPUT AXIS. Further more, all of the other effects (Yaw, Long, Lat etc) will alter ALL 6 of the output axis. If your actuators are not in sync and not calibrated, they will work against each other and use excess power and possibly damage the whole platform.
    I don't think you have seen this done with the Math plugin.
  16. aliaero
    aliaero New Member
    Pakistan
    277Coins
    @Sironame
    First of off all i am really thankful to you because of you Explanation
    and
    What i understand from your point is that Math plugin can produce effects only for one axis and for Stewart Platform we have to take care of all the three axis as they are all coupled in Stewart Platform like configueration..is that Right?
    Additionally can you please help us with that math pluginn that how to write code As i am quite newbie in Programming!
    and what if we just simulate effects in One axis, can we use the standard math plugin in that case?
    Looking forward to your Reply!
    Regards
    Ali
  17. Frakk
    Frakk Active Member
    328Coins
    There is a program for a servo arm actuated steward platform on the forum, but those geometrical calculations are totally different than what you have.
    If you are good at geometry and algebra, you could come up with a formula and try to simulate it first. I don't think a lot of information is available on the internet because most of the companies using it will definitely not share it. Good luck!
  18. Mambo
    Mambo New Member
    Czech Republic
    288Coins
  19. Frakk
    Frakk Active Member
    328Coins
    So there it is.
    Anyone up for a good reading? :D
  20. RaceRay
    23,862Coins
    Mambo, what about copyright issues about the book? Are we allow to offer it here? Otherwise please delete the link and send it via pm.
    Btw. Amazing book!!! :) But not easy readable, needs a lot of studying.
    regards
