6DOF COR point question
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Deleted member 51784, Jun 21, 2025.
  1. Deleted member 51784
    By design, a cars' COR is between the driver's and passenger's seat. While a small GA aircraft COR is behind and below or behind and above the pilots seat, depending if you flying a high or low wing aircraft. A helicopter's COR is behind and above. Does the 6DOF game/rig simulate the COR of the vehicle your in? Or is the COR the center of the rig?
    I know it's a weird question but I'm designing a helicopter rig, and need to know if I should build the COR into the rig itself.
  2. Misanthrop
    Misanthrop Active Member
    754Coins
    In Simhub you can change the cor position to your needs
    153,001Coins
    +11,116 / 56 / -2
  4. blodirek
    blodirek New Member
    62Coins
    Add the difference between a plane and a car to the COR
