Question Absolute Value from Simtools?
Discussion in 'SimTools DIY Version' started by PMK, Feb 27, 2020.
  1. PMK
    PMK Member
    Australia
    125Coins
    I'm tuning my seatbelt tension system and was wondering if it is possible to get the absolute value for a degree of freedom from the game?
    i.e sway has positive and negative values for left/right accelerations, this results in the seatbelt tightening for one direction of sliding and loosening for sliding in the other direction.
    I'm running a JRK 12v12 so probably not much room for custom programming this outside of simtools.
  2. yobuddy
    49,199Coins
    No, but it could probably be a filter for an axis assignments plugin.
    The axis would only be half used thou. (maybe that's ok thou).
    what kind of motor do you have it connected to?
    I could think of a couple of ways to connect it so it would not matter which way the motor spun.
    But i have no idea what your setup looks like,
    Take care,
    Dustin
