AC - 2 monitor set up, can not get it to work.
Discussion in 'Assetto Corsa' started by helisfreak, Jan 25, 2017.
  1. helisfreak
    helisfreak Member
    Phoenix, AZ
    591Coins
    Hey guys,
    I am having a lot of trouble trying to get my monitors to work. Basically I have two monitor, both hook up to the same graphic card. I want to run AC on one monitor and the other monitor run my desktop so I can tune the game.
    1. Primary
    2. Game
    I had it set as Extend Display, when I launches the game, when it's in the menu, I can press F11, then I can now resize the window and move it to the extended monitor and full screen it... It seem to work. However, as soon as the race start, it relaunch the window and move it back to my primary window, which now cover the desktop again.
    Of course when racing, if press F11, then I get the damn rear mirror... no longer the option to move the window.
    Any advise?
  2. abs
    consultant
    Montreal
    765Coins
    3DOF, SCN5
    hello, remove (or unplug the vga or hdmi) the non gaming screen.
    set asseto c to the res of the remaining gaming screen (set also that gaming screen as primary screen - might be done already as it is alone)
    plug the secondary and extend it in the display setting (right click with mouse on screen)
    when you open simtoolsgame manager drag the window in the extended screen.
    that is it . The unplugging thing is not that necessary but might simplify a bit the process ( you might want to try and skip it)
    this is what I do . I run 3 x 27 as gaming display on my gaming PC + one tiny usb display to run simtools game manager + z1 server so that I can tstop and twick settings
    and simtools game engine is run by a second PC with 2 screens where I can see two instance of z1 dashboard and simtoolsgameengine for the twicking
  3. Blame73
    Blame73 Well-Known Member
    8,315Coins
    I paste here from a post I wrote in the AC forum
    http://www.assettocorsa.net/forum/i...lternative-launcher.33824/page-41#post-797959
    I got two monitors, one on the desk and one on the motion rig. Whenever I want to simplay, I run a batch that also switches my monitors; to do so I use a program, Monitor Profile Switcher that you can find here. This program allows you to create multiple monitors profiles, and you could also save them and load them via command line as xml files.
    This is my batch file:
    • start "" C:\Users\Davide\Desktop\Sensori\MonitorSwitcher.exe -load:C:\Users\Davide\Desktop\Sensori\MS_sx.xml
      • monitor switcher
    • start "" "C:\Program Files (x86)\SimTools\SimTools_GameManager.exe"
      • motion simulator game manager
    • start steam://rungameid/244210
      • Assetto Corsa
    • start "" "C:\Users\Davide\Desktop\Assetto Corsa Tools\DriveVibe\DriveVibe.exe"
      • bass shaker tool
    • start "" "C:\Users\Davide\Desktop\Assetto Corsa Tools\Content Manager.exe"
      • AC altrenative launcher
    • start "" "C:\Program Files (x86)\Britton IT Ltd\CrewChiefV4\CrewChiefV4.exe"
      • AC info app
    The first bold line loads the xml that switches the monitors
    EDIT: when I'm finished playing I have another batch that switches monitors back and closes the tasks I don't need anymore
  4. gorzasty
    gorzasty Active Member
    photographer, IT specialist
    Poland, Wrocław
    1,060Coins
    Is it really so comlicated? If I have 2 monitors I would set "run in window mode' in AC and choose resolution of the one monitor (if its HD screen - 1920 x 1080). In windows make suer that screens are not gruped in the video drivers.
