Question Alternatives to SMC3
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by PhillyNJ, Jun 20, 2024.
  1. PhillyNJ
    PhillyNJ New Member
    115Coins
    I am currently using SMC3 to control my 2DoF rig with 2 IBT-2 controllers. The author did a great job with the SMC3 firmware and SMC3 Utilities. However, I have to ask; can the firmware be simplified? For me, it was a pain to configure the PWM, not because there is an issue with the firmware, but because PWM is a bit over my head. If you google Arduino IBT-2 example code, there are some basic examples, which in my option simplify controlling the motors. For examples, see blog post. They provided a very simple but effective example on how to control the speed and direction with a Potentiometer. Adding a Hall effect sensor for each motor would be simple with setting the "home" position and help limit the motors range. Also, maybe using the pots to control the speed.
    Am I under-simplifying it or am I missing something important? Like I said, the author did a great job with SMC3 and it seems to be the popular choice.
    I am interested and anyones opinion on this.
    Thanks.
    146,116Coins
    +10,809 / 52 / -2
    I think you are under-simplifying a bit, as when it comes to motion rigs it is not just about making something move, it is about tuning to optimise response for what can be diverse hardware used.
    SMC3 takes that a bit further, in that it is meant to be generic for a diverse range of controllers, not just motors, so there is an additional learning curve and configuration to have that range of flexibility in one tool, done in a way that also includes visualisation of setting responses.
    So yes it is possible to simplify beyond SMC3, if it is narrowed to particular controller and motors, but even then there will be a degree of tuning required to get the best out even a known combination, as there is a degree of hardware differences in manufacturing even the same hardware.
  3. dryas123
    dryas123 New Member
    - 132Coins
    So in your linked blog post they simply turn the motor in to one direction or another and they modify the speed in a very simple way via PWM (analogWrite()). However, with motion you need to compare the motor position with the desired position that you got by Sim Tools, FlyPT Mover or other software. If the distance is far away you need to move faster, if it's near slower and all of this in a dynamic way. For this a PID controller is used (and I guess that's what you are talking about as you normally don't have to configure PWM with SMC3) which needs to get tuned. There is not really a good alternative to this approach available and in most cases you only need to tune P and not I or D.
    However, I'm currently working on a modern alternative to SMC3 based on a 32 bit Microcontroller for 6 motors at once. As I'm rewriting the full firmware and management tools from scratch it would be great to get some input how this could be done more user friendly.
    Best,
    Ben
  4. PhillyNJ
    PhillyNJ New Member
    115Coins
    I am interested to how you are coming along. Also, I am a programmer by day and maker by night, so I am not afraid to at least try to develop a simpler version, even if I fail.
    Thanks both of you for the input.
