And so it starts (2DOF build)
Discussion in 'DIY Motion Simulator Projects' started by Mark Nalder, Aug 5, 2016.
  1. Mark Nalder
    Mark Nalder Member
    England
    646Coins
    Excited to get started on this Race Simulator
    Lots still to decide upon, but the base frame has been selected.
    I'm going to try to copy the SimXperience 2 design as best I can
    Like this
    I've found a UK fabricator that will do the Steelworks using 25mm box (smaller than the design) for circa £ 200
    so there is little point in my buying the steel and a welder - it works out to be the same.
    Firstly I'm getting my head around the way things work and have spent 10 mins with my R/C gear to test the Arduino Servo system
    I'll post as much as I can as the build progresses -
    Happy for flaming or encouragement :)
    Vass
  2. Mark Nalder
    Mark Nalder Member
    England
    646Coins
    parts list is growing nicely
    I now have.....
    Wheel and Pedals
    Pots
    Rose joints
    universal joint (ex-MOD jeep)
    on order now are...
    Motors (thanks Lee)
    Chair
    Jrk 12v12 controller cards
    once I have everything, I will be able to draw up plans for framework
    (PC and Screens come later but I have an Alienware i7)
    looks like September before I have everything
    budget will hit circa £ 880 + computer and screen
  3. BlazinH
    16,625Coins
    So what motors did you end up purchasing?
  4. Mark Nalder
    Mark Nalder Member
    England
    646Coins
    A fellow UK member is bulk ordering so I've gone that route. Gave up trying to find a cheaper option.
    Buy right or buy twice I guess.
  5. BlazinH
    16,625Coins
    So are you bulk ordering motors from pgsaw then?
  6. Mark Nalder
    Mark Nalder Member
    England
    646Coins
    pgsaw? USA eBay ?
  7. Daguru
    Kitchen installer
    Wales uk
    454Coins
    Motion platform
    Hi good luck with your project where are you in the uk ?
  8. Mark Nalder
    Mark Nalder Member
    England
    646Coins
    I'm south coast. :) hope to start build in about 4 weeks
  9. Mark Nalder
    Mark Nalder Member
    England
    646Coins
    Universal joint came in the post today (can for scale)
  10. Mark Nalder
    Mark Nalder Member
    England
    646Coins
    Postman came today
  11. Nick Moxley
    17,056Coins
    As i said, make sure to click the Blue plugs together before soldering to the board.
  12. lcturkey
    lcturkey Member
    163Coins
    Hi Mark,
    Universal Joint looks so small do you think it can handle your weight ?
  13. noorbeast
    148,730Coins
    +10,915 / 54 / -2
    The uni joint actually looks bigger and more robust than what they use in commercial CXC sims, so I am sure it will be fine.
  14. Mark Nalder
    Mark Nalder Member
    England
    646Coins
    yeh, its off a MOD Jeep! I'd like to think if a Jeep can't break it, I cant ! :) thanks for your concern
  15. Mark Nalder
    Mark Nalder Member
    England
    646Coins
    Fan unit for the 2 x JRK's -
    building the enclosure soon, possibly from Perspex, undecided.
    30 LED Blue fan unit 120mm
  16. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    got almost the same joint, and it works great even under heavy load :grin, nice to see your work in progress.
  17. Mark Nalder
    Mark Nalder Member
    England
    646Coins
    The 40A PSU's came today !
  18. Mark Nalder
    Mark Nalder Member
    England
    646Coins
    testing the wiring and setting up the JRK boards today
    hopefully with the POT's calibration test
    in readiness for the proper motors later on
  19. Mark Nalder
    Mark Nalder Member
    England
    646Coins
    can any one post a link to the forum that has the walkthrough for the JRK configuation please?
    My POT is moving the graph nicely - but RUN MOTOR does nothing
  20. noorbeast
    148,730Coins
    +10,915 / 54 / -2
