ard/mm and jrk
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by bruce stephen, Jul 19, 2015.
  1. bruce stephen
    general contractor
    michigan
    9,112Coins
    has anyone tried ard and jrk on the same rig at the same time? Is this possible? lets say 3dof shoulder mount with traction loss. jrk for the shoulders and ard/mm for tc you could run stronger motor for tc. maybe a dumb question. I'll leave that up to the smart guys.
  2. Pit
    30,451Coins
    You can use different interfaces using SimTools.
    • Agree Agree x 3
  3. bruce stephen
    general contractor
    michigan
    9,112Coins
  4. eaorobbie
    20,440Coins
    Gday Bruce , yes the concept is sound as @Pit has advised. On another note the MM and Jrk have the same driver on them, so unless you run the MM in one motor mode (which they can burn up quickly,must be careful) you wont be able to run a bigger motor with it.
    But YES you can Run a ARD and JRK together.
