Question AssettoCorsa, engines stop working after collision on track
Discussion in 'DIY Motion Simulator Projects' started by motiondynamics, May 23, 2025.
  1. motiondynamics
    motiondynamics Member Gold Contributor
    1,161Coins
    2DOF, 3DOF, DC motor, AC motor, SimAxe, Arduino, Motion platform, 6DOF
    Hello everyone.
    Today I tried to use AssettoCorsa, but I have a problem with the motion: everything works, but as soon as the car on the track (AssettoCorsa) crashes badly... the motors stop working.
    It seems that when the car crashes, there is too much data on the USB communication port and therefore it crashes...
    Here is what I am using:
    1) Arduino
    2) Windows 10
    3) AssettoCorsa (Steam)
    4) Plugin "AssettoCorsa_GamePlugin.2.0.7.1."
    Is it a plugin problem?
    Is there a new plugin?
    Please help me, thanks
    151,437Coins
    +11,038 / 56 / -2
    It could be a number of things, poor settings, power spikes in fast reversals shutting down the PSU, electrical interference, USB disconnects, or some combination.
    Can you please post pictures of all your settings.
    Are there any error messages or Windows sounds when it stops?
  3. motiondynamics
    1,161Coins
    Hi Noorbeast, the power supply is ok, so I exclude that this is the problem.
    The percentages of the effects in Simtools are set very low, so I also exclude this.
    I think the problem is due to an excess of data on the COM port that conflicts with pedals and steering (4 USB ports used).
    The problem occurs only when the car goes off the track with serious damage, so I think that at that moment a data traffic is created on the Arduino USB port.
    Yes, when the motors stop working and therefore when Simtools no longer transmits data to Arduino, the computer emits a short Beep.
    151,437Coins
    +11,038 / 56 / -2
    You can map your USB use to internal USB controllers, to check and even out the load, please see the FAQs here: https://www.xsimulator.net/community/faq/simtools-usb-issues-can-cause-crashes.313/
