Axis limit max 87%
Discussion in 'DIY Motion Simulator Projects' started by dualclick76, Mar 26, 2015.
  1. dualclick76
    dualclick76 Active Member
    italia
    11Coins
    Ciao a tutti, chiedo un parere su ciò che il problema potrebbe avere la mia sim.
  2. dualclick76
    italia
    11Coins
    I can not set a value greater than 87% in axis limit of game engine, the simulator 2 dof crashes
  3. dualclick76
    italia
    11Coins
    ideas on what could be the problem? Using Arduino + moster moto Schield + code arduino racingmat thanks in advance
  4. Pit
    30,451Coins
    SimTools crashes well known as a app crash on windows?
  5. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,796Coins
    Not sure on the Ards (I use JRK) but sounds to me like your Feedback is going out of range.
    I noticed my Simtools will crash if "feedback disconnected" is detected.
    Again, I use JRK, so might not be your issue, just something to check??
  6. dualclick76
    italia
    11Coins
    thanks for the prompt response will try '
  7. dualclick76
    italia
    11Coins
    the simulator crashes, virtual axis continues to show the different percentages of axis used
  8. Pit
    30,451Coins
    @dualclick76 why we have to get all details out of you or rather about the issue. Still I do not know what exactly is crashing.
  9. RacingMat
    20,976Coins
    that's weird... what is crashing?
    - Simtools Game Engine / Game Manager?
    - simulator stop moving?
    - what are Arduino led's state and color?
    - your Power Supply Unit is in default?
    maybe you could do screenshots or a video?
  10. dualclick76
    italia
    11Coins
    Code:
    Arduino code for dynamic playseat 2DOF
    Created 24 May 2011 by Jim Lindblom   SparkFun Electronics https://www.sparkfun.com/products/10182 "Example Code"
    Created 24 Apr 2012 by Jean David SEDRUE Version betatest26 - 24042012 http://www.gamoover.net/Forums/index.php?topic=25907
    Updated 20 May 2013 by RacingMat in english http://www.xsimulator.net/2dof-wiper-motor-playseat/ in french : http://www.gamoover.net/Forums/index.php?topic=27617
    Updated 30 April 2014 by RacingMat (bug for value below 16 corrected)
    #define BRAKEVCC 0
    #define RV  2 //beware it's depending on your hardware wiring
    #define FW  1 //beware it's depending on your hardware wiring
    #define STOP 0
    #define BRAKEGND 3
    #define pwmMax 255 // or less, if you want to lower the maximum motor's speed
    // defining the range of potentiometer's rotation
    const int potMini=360;
    const int potMaxi=800;
    #define motLeft 0
    #define motRight 1
    #define potL A5
    #define potR A4
    //  DECLARATIONS
    /*  VNH2SP30 pin definitions*/
    int inApin[2] = {
      7, 4};  // INA: Clockwise input
    int inBpin[2] = {
      8, 9}; // INB: Counter-clockwise input
    int pwmpin[2] = {
      5, 6}; // PWM input
    int cspin[2] = {
      2, 3}; // CS: Current sense ANALOG input
    int enpin[2] = {
      0, 1}; // EN: Status of switches output (Analog pin)
    int statpin = 13;  //not explained by Sparkfun
    /* init position value*/
    int DataValueL=512; //middle position 0-1024
    int DataValueR=512; //middle position 0-1024
    // INITIALIZATION
    void setup()
      // serial initialization
      Serial.begin(115200);
      // initialization of Arduino's pins
      pinMode(statpin, OUTPUT); //not explained by Sparkfun
      digitalWrite(statpin, LOW);
      for (int i=0; i<2; i++)
        pinMode(inApin[i], OUTPUT);
        pinMode(inBpin[i], OUTPUT);
        pinMode(pwmpin[i], OUTPUT);
      // Initialize braked for motor
        digitalWrite(inApin[i], LOW);
        digitalWrite(inBpin[i], LOW);
    ///////////////////////////////// Main Loop ////////////////////////////////////
    void loop()
      int sensorL,sensorR;
      readSerialData();   // DataValueR & L contain the last order received (if there is no newer received, the last is kept)
      // the previous order will still be used by the PID regulation MotorMotion Function
      sensorR = analogRead(potR);  // range 0-1024
      sensorL = analogRead(potL);  // range 0-1024
      motorMotion(motRight,sensorR,DataValueR);
      motorMotion(motLeft,sensorL,DataValueL);
    // Procedure: wait for complete trame
    void readSerialData()
      byte Data[3]={
        '0','0','0'          };
      // keep this function short, because the loop has to be short to keep the control over the motors
      if (Serial.available()>2){
        //parse the buffer : test if the byte is the first of the order "R"
        Data[0]=Serial.read();
        if (Data[0]=='L'){
          Data[1]=Serial.read();
          Data[2]=Serial.read();
          //  call the function that converts the hexa in decimal and that maps the range
          DataValueR=NormalizeData(Data);
        if (Data[0]=='R'){
          //  call the function that converts the hexa in decimal and maps the range
          DataValueL=NormalizeData(Data);
      if (Serial.available()>16) Serial.flush();
    void motorMotion(int numMot,int actualPos,int targetPos)
      int Tol=20; // no order to move will be sent to the motor if the target is close to the actual position
      // this prevents short jittering moves
      //could be a parameter read from a pot on an analogic pin
      // the highest value, the calmest the simulator would be (less moves)
      int gap;
      int pwm;
      int brakingDistance=30;
      // security concern : targetPos has to be within the mechanically authorized range
      targetPos=constrain(targetPos,potMini+brakingDistance,potMaxi-brakingDistance);
      gap=abs(targetPos-actualPos);
      if (gap<= Tol) {
        motorOff(numMot); //too near to move
      else {
        // PID : calculates speed according to distance
        pwm=195;
        if (gap>50)   pwm=215;
        if (gap>75)   pwm=235;
        if (gap>100)  pwm=255;
        pwm=map(pwm, 0, 255, 0, pwmMax);  //adjust the value according to pwmMax for mechanical debugging purpose !
        // if motor is outside from the range, send motor back to the limit !
        // go forward (up)
        if ((actualPos<potMini) || (actualPos<targetPos)) motorGo(numMot, FW, pwm);
        // go reverse (down)
        if ((actualPos>potMaxi) || (actualPos>targetPos)) motorGo(numMot, RV, pwm);
    void motorOff(int motor){ //Brake Ground : free wheel actually
      digitalWrite(inApin[motor], LOW);
      digitalWrite(inBpin[motor], LOW);
      analogWrite(pwmpin[motor], 0);
    void motorOffBraked(int motor){ // "brake VCC" : short-circuit inducing electromagnetic brake
      digitalWrite(inApin[motor], HIGH);
      digitalWrite(inBpin[motor], HIGH);
    void motorGo(uint8_t motor, uint8_t direct, uint8_t pwm)
      if (motor <= 1)
        if (direct <=4)
          // Set inA[motor]
          if (direct <=1)
          else
          // Set inB[motor]
          if ((direct==0)||(direct==2))
          else
          analogWrite(pwmpin[motor], pwm);
    void motorDrive(uint8_t motor, uint8_t direct, uint8_t pwm)
      // more readable function than Jim's (for educational purpose)
      // but 50 octets heavier ->  unused
      if (motor <= 1 && direct <=4)
        switch (direct) {
        case 0: //electromagnetic brake : brake VCC
          break;
        case 3: //Brake Ground (free wheel)
          break;
        case 1: // forward : beware it's depending on your hardware wiring
          break;
        case 2: // Reverse : beware it's depending on your hardware wiring
          break;
    // testPot
    void testPot(){
      Serial.print(analogRead(A4));
      Serial.print(";");
      Serial.println(analogRead(A5));
      delay(250);
    void testpulse(){
      int pw=120;
      while (true){
        motorGo(motLeft, FW, pw);
        delay(250);
        motorOff(motLeft);
        delay(250);
        motorGo(motLeft, RV, pw);
        delay(250);
        motorOff(motLeft);
        delay(500);
        motorGo(motRight, FW, pw);
        delay(250);
        motorOff(motRight);
        delay(250);
        motorGo(motRight, RV, pw);
        delay(250);
        motorOff(motRight);
        Serial.println("testpulse pwm:80");
        delay(500);
    // Function: convert Hex to Dec
    int NormalizeData(byte x[3])
      int result;
      if ((x[2]==13) || (x[2]=='R') || (x[2]=='L'))  //only a LSB and Carrier Return or 'L' or 'R' in case of value below 16 (ie one CHAR and not 2)
        x[2]=x[1];  //move MSB to LSB
        x[1]='0';     //clear MSB
      for (int i=1; i<3; i++)
        if (x[i]>47 && x[i]<58 ){//for xA to xF
          x[i]=x[i]-48;
        if (  x[i]>64 && x[i]<71 ){//for x0 to x9
          x[i]=x[i]-55;
      // map the range from Xsim (0 <-> 255) to the mechanically authorized range (potMini <-> potMaxi)
      result=map((x[1]*16+x[2]),0,255,potMini,potMaxi);
      return result;
  11. dualclick76
    italia
    11Coins
    This is the code I used
  12. dualclick76
    italia
    11Coins
    Simtools Game Engine / Game Manager continue to function
  13. dualclick76
    italia
    11Coins
    Power Supply Unit HP DPS-600PB DL380 G4 575W
  14. dualclick76
    italia
    11Coins
    when axis limit is 87% leds are switched ON and RX during operation.
    when axis limit is 100% leds are first ON and RX, just hangs only ON, RX goes off.
  15. Pit
    30,451Coins
    Seems to be an issue of the range of the potentiometer's
  16. dualclick76
    italia
    11Coins
    in what sense?
