Axis Settings for Traction Loss
Discussion in 'SimTools DIY Version' started by CoachKalk, Sep 24, 2014.
  1. CoachKalk
    CoachKalk Member
    970Coins
    After pulling my head out of my %$$ with the JRK problem, I mounted and configured my traction loss motor tonight.
    I already have my 2 motors set up (Roll, Pitch, Heave, Sway and Surge) on Axis 1 & Axis 2 and working good.
    I am not sure how to incorporate the third motor? I have Interface 3 set up on the third com port.
    Do I add Yaw to Axis 1 and Axis 2?
    Do I only use Yaw on Axis 3?
    I apologize in advance if this is obvious and I am missing something. I will sat I tried putting Axis 3 at Yaw 80% and Roll 20%. I tested with the Game Engine and the Traction Loss motor was turning when I used the Roll and Pitch slider. I am not sure if is was supposed to. When I used the Yaw slider - no action at all.
    Thanks,
    Steve
  2. value1
    14,865Coins
    Hi @CoachKalk
    • add a picture of your setup. The axis assignment depends somewhat on the design.
    • I recommend to use "Traction Loss" where available. There are several plugins that provide this data as "Extra1"
  3. CoachKalk
    CoachKalk Member
    970Coins
    @value1 - here is a pic showing my setup. I am playing LFS. I will check to see if Traction Loss is
  4. eaorobbie
    20,448Coins
    Ok so you are best using traction loss , @value1 has kindly added this to the popular game plugins , it is contained in Extra1 in most cases.
    Check the updated in the Game Plugin resource section and it will inform you if traction loss is avail on a particular plugin.
    So Interface 3 will be the third Jrk running you traction loss and will be Axis 3 and uses Extra1 at 100%
  5. Edson Lourenço Bezerra
    Edson Lourenço Bezerra Edson Bezerra - Desenvolvedor Open Source
    Analista de Sistema
    Jundiaí
    147Coins
    2DOF, 3DOF, DC motor, Arduino, Motion platform, 4DOF
    Seria viável se permitissemos analisar visualmente o ângulo e o espaço desse movimento.
    149,687Coins
    +10,954 / 54 / -2
    Please include an English Google Translation, it is a forum requirement: https://www.xsimulator.net/community/threads/forum-rules.9527/
    I have done it for you here -
    It would be feasible if we allowed to visually analyze the angle and space of this movement.
  7. Edson Lourenço Bezerra
    Analista de Sistema
    Jundiaí
    147Coins
    In my case as can be seen in the video: it is a specific movement for traction loss.
  8. Edson Lourenço Bezerra
    Analista de Sistema
    Jundiaí
    147Coins
    Forgive me, my self-transcribing browser for PT-br
