axle in sim
Discussion in 'XSimulator Q&A/FAQs - Outdated' started by Papifix, Jan 16, 2011.
  1. Papifix
    Papifix Member SimAxe Beta Tester
    im Ruhestand
    Friedberg
    562Coins
    I found this in iRacing forum.
    Is this correct ?
  2. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    437Coins
    Yes, although in X-Sim, Norm is referred to as vertical. Can you post the drawing without the sketch. I get asked for this all the time. It would be a helpful drawing to have on hand.
  3. Papifix
    im Ruhestand
    Friedberg
    562Coins
    Sorry Bernhard,
    I have only this picture.
    Best Regards
  4. Papifix
    im Ruhestand
    Friedberg
    562Coins
    If I try rear Rear Traction Loss simulation is it in the profiler the effect 29 ?
  5. bvillersjr
    Ohio, USA
    437Coins
    It's Best to use 32 to start. The trick is to get the correct minumum value. In the profile pack I posted you will find 20 or so examples.
  6. Papifix
    im Ruhestand
    Friedberg
    562Coins
    I see in your list is 32 Yaw acceleration for rfactor but I try iRacing.
    In iRacing 32 is Car Velocity Y.
    Please was is this for an effect ?
  7. bvillersjr
    Ohio, USA
    437Coins
    Yes. You will find them on the third axis and sometimes in the seat axis as well. You should be able to take these values and put them in your own motion profile. If you're driving with the same car, you will get the proper feel. Once you see it working in a car that you know the numbersa for from one of the existing profiles, you can experiment from there.
  8. Papifix
    im Ruhestand
    Friedberg
    562Coins
    Thanks Bernhard.
    Best Regards
