BassShaker Profil
Discussion in 'X-Sim² profiles' started by Nima, Dec 16, 2009.
  1. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    531Coins
    Sirnoname has make a Plugin for Buttkicker and other Shakers were are work with Sound.
    Is it a very nice Plugin.Many Thanks Martin for this.You can use the X-Sim values and the Plugin give it too the Soundcard.
    I have make a first Profil for this.The Plugin is in the new X-Sim soft 2.1.0.5.For older X-Sim Soft
    you mast make the BassShaker .dll in the Interface Plugin folder in X-Sim.
    I use in the Plugin Minimum frequency 28Hz
    Maximum frequency 170Hz for a Big V8 80-120HZ
    Minimum volume 80%
    It is for the Megane 2.0 4Zylinder
    Nima
  2. ledfoot
    ledfoot Member
    IT Manager
    Toronto, Canada
    22Coins
    Thanks Niels,
    I did some testing with the buttkicker last night and I like the way it works so far.
  3. johnfatboy
    johnfatboy New Member
    very nice...i have to shakers connected to my simulator, one at the pedals and one at my seat... looking forward to try this out. 8)
  4. Schnullerbacke
    Schnullerbacke New Member
    Photographer / Videographer
    Germany near Munich
    369Coins
    I also tested the plugin and the profile together with Nima this afternoon. It was pretty good, but there occurred another problem concerning my sim: I really have to get the Buttkicker Gamer better dampened !!!
    Do you have any idea on what's the best way to do that ? Who is also using the Buttkicker Gamer ?
    The problem is, that the Buttkicker CANNOT be as precisiously as it should be, because the vibrations do affect the whole sim. Any suggestions ?
    I would try to set dampers between the seat consoles and the seat unit (aluminium profiles) AND another two dampers between the actuator arms and the base rig. What do you think ?
  5. Nima
    Glaser
    Bad Zwischenahn
    531Coins
  6. Schnullerbacke
    Germany near Munich
    369Coins
    I know it from a few home cinema fellows... but it's pretty expensive.
    I'd rather buy an BK mini - but I'm wondering which amp I should take to power it. Maybe a car hifi mono sub amp would do the job...
    But at first I have to dampen my sim :? !
  7. jimiTES
    jimiTES New Member
    - 45Coins
    Hi
    I have been testing Nima profile for the buttkicker. I think this is a very good a idea using Xsim for activating buttkicker.
    But i can only feel the vibrations produced by the engine, nor the ones created by the curbs. Am i missing something?
    Thank you.
  8. Nima
    Glaser
    Bad Zwischenahn
    531Coins
    hi jimi,
    this wars the first bassprofil i can send you a new one.how many rpm have the car were are you want drive?what is your play?what kind of bassshaker have you.say this and i make tomorow a new profil for you.in my last profil i have only engine effects and collisions effects.
  9. jimiTES
    jimiTES New Member
    - 45Coins
    Thank you Nima.
    I play mainly rFactor, and I´m using a Buttkicker gamer.
    The car i´m riding now is a F1 from my league. 18000rpm.
    Thank you for the support.
  10. Nima
    Glaser
    Bad Zwischenahn
    531Coins
    hi,
    i have make a profil for you test it please.i dont have test it.
    in the plugin i have minimum frequenzy 40 Hz
    maximum frequenzy 116 Hz
    minimum volume 80 % you can use the volume in play
    you dont must stop the profiler.i have a ibeam bassshaker you must look what
    is the right minimum volume for the buttkicker.
