Brauche Hilfe
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by catweazle, Oct 31, 2016.
  1. catweazle
    catweazle New Member
    Greven
    334Coins
    2DOF, 3DOF, DC motor, Arduino, Joyrider, SimforceGT, Motion platform
    Hallo
    da hab ich schon die ersten Fragen;
    ich bekomme keine verbindung between LFS und Spiel-Manager zustande
    ich habe alle Einstellungen nach Anleitung gemacht, Aber beim Start von LFS geht das Connected -Fenster
    nicht auf Blau. Was mache ich falsch?
    Für Hilfe wäre ich sehr dankbar.
    Translation
    Hi
    I already have some questions:
    I have no connection between LFS and the GameManager.
    I have made all the settings in the manual, however when I start LFS the connected window does not turn blue. What am I doing wrong?
    I'll be very thankful for help
  2. Historiker
    Michigan USA
    9,201Coins
    Hi @catweazle you will get more help if you post in English. You are of course welcome to also post in your native language but the official language of this forum is English. There are several Deutsch speakers here that might be able to help with translation but the best thing to do would be to use Google translate to post in both languages.
    148,628Coins
    +10,909 / 54 / -2
    You need to give far more details.
    Can you confirm you have patched LFS for motion?
    Was LFS run at least once without motion? If not unpatch, run LFS and drive around a bit, close LFS then re-patch.
    Can you please describe your hardware and post pictures of your Interface and Axis Assignment settings.
