Building my own chair, want info.
Discussion in 'Rock n Ride simulators - Outdated' started by Alekoy, Dec 22, 2006.
  1. Alekoy
    Alekoy New Member
    Hello, I am in the planning part of putting a chair together myself.
    I will use it for Flightsim and some driving-games.
    I allready have a Velleman USB-card, chair and the material for building the cage, pneumatic cylinders and valves are going to be ordered soon.
    the plan is to make it modular so that i can exchange parts of the superstructure to make it suited for wheel and pedals for driving OR joystick, throttle and pedals for flightsim.
    the questions are:
    What movement are recomended, how many degrees +/- on pitch, and +/- on roll?
    is there a recomended pivot-point for the axes?
    is there any need for potentiometers on the axes, so that the X-sim software knows when the chair is in center or end position?
  2. Alekoy
    Alekoy New Member
    Okay,
    Can you use the Xsim software/vellemancard for the frex-chair to?
    I think I'll probably build a R'n'R first, and then see how it works out, and then maby build a Frex later on
    btw.
    DOES the R'n'R use potmeters to find the center and end positions, and the current position?
  3. Renoboss
    Renoboss Member SimAxe Beta Tester Gold Contributor
    Work, Motion Simulator and High Tech Fishing
    Netherlands (Frisian)
    297Coins
    2DOF, SCN5
    Hello Alekoy,
    Yes it does , somehow through Velleman USB-kit it seems to have some bugs! I have the Velleman USB-kit and don't seem to have real bugs!
    Right now i'm building a new extension controller (with a Bourns 10 turn potentiometer). I hope next week 1 prototype will be ready!
    Like you I like Flightsims and racesims!
    For Flightsims the R´n´R chair is the real way to go!
    (in MS FSX and the room completely darkened i get the real stomach feeling!!)
    For Racesims I think Frex style setup is needed ( Shige T is really right with his setup). Like mentioned in other posts on this site i´m designing
    a Frex setup to be used by 50 mm. diameter 270 mm. hub pneumatic cylinders!
    I want to use Aluminium profiles to be able to change to cylinder positions and angles during setup testing. The current design will use 40x40 mm. profiles.
    Before i go that way i want to test the new valveblock and new potentio´s!
    I´ll keep everybody updated!!
    http://x-simulator.de/forum/pneumatisch ... n-t85.html
  4. Alekoy
    Alekoy New Member
    allright
    I am mainly a Flightsim-person, I really like racesims to, but mostly they last like a week or two before I get bored of them.
    But flightsim, with lots of addons, so that the tarrain looks like it is in reality, and when i see and recognise landmarks here in Norway, it is majestic.
    I have a projector-setup, and I am also thinking about buying a TrackIR-kit, i guess the sensor must be mounted on the chair-cradle somehow.
    but i will tackle that later on.
    I have bought sylinders and valves now, 10 stroke, two for the roll and two for the pitch, like your chair.
  5. Alekoy
    Alekoy New Member
    okay, about the screens/projector, that was what I was worried about. maby I'll use the projector until later, and then go for a 3-monitor setup on the chair, when my wallet allows it... (I'm restauring a 67 Chevrolet Chevelle on the rest of my sparetime..)
    The valves i bought are a SMC-valve array (manifold), with 10 valves on it (bought used, from a factory nearby) and i THINK i can modify it to do the same job as the normal (single) ones, time will show, and if i dosent work, I'll have to buy single ones. (the factory had some single valves to, but only 6 of them...
    jupp, only the addons I have are freeware, but still VERY acurate.
    and I will probably use a laptop i have for flightmap and controlling the r'n'r chair (a single computer do other things than control the X-sim software? and not be dedicated to the x-sim?)
  6. Alekoy
    Alekoy New Member
    okey,
    the plan is anyways to have one computer to run Flightsim, and another one to run the x-sim software and mapsoftware
