Can Project CARS 3 share memory ?
Discussion in 'Project Cars' started by Gouffy56, Nov 16, 2022.
  1. Gouffy56
    Gouffy56 New Member
    298Coins
    4DOF
    Hi!
    On my gamers, on Project Cars 2, the share memory setting offers the following options: NO, YES and Project Cars . If you select YES, then Project Cars 2 can share its memory with other applications such as SIMTOOLS to drive a rig (I have two five motions rigs).
    On Project Cars 3, the only options I have regarding the share memory setting are: NO, Pjoject Cars 1 and Project Cars 2. This means I cannot activate my rigs with Project cars 3. Is there any means correcting this situation, I mean having my rigs' actuators working while playing with Project Cars 3 ?
    Regards
  2. value1
    14,751Coins
    There are two similar yet different sets of telemetry data available for PC3: Either the original PC1 set or the slightly modified dataset from PC2. There is no specific dataset for PC3. So you can chose either or.
  3. Gouffy56
    Gouffy56 New Member
    298Coins
    4DOF
    Youpy! I found what was going on. Based on your imput and the fact that PC3 was correctly patched with a valid pluggin (I used 2 from 2 different sources), I dug into the system parameters settings and I found there was a discrepancy between the memory setting (PC2) and the UDP mode (No) and protocol (PC1) settings; I have no idea what UDP stands for, but anyway by setting the mode to 4 and the version to PC2, it works now. Thank you for your paramount input.
