Question Can Simtools pull data from a 3rd party telemetry via UDP?
Discussion in 'SimTools DIY Version' started by Moe Colontonio, Mar 17, 2021.
  1. Moe Colontonio
    New Jersey USA
    758Coins
    I've been trying to get my Gbelt & Gseat working with simtools.
    I recently came across a 3rd party telemetry program called "Space Monkey". This can pull telemetry from DCS, and MSFS2020 as well as many other programs, and output it via several different formats. One is UDP, and the designer told me that Simtools can likely read this data.
    I have no clue how to proceed from here. I read this thread, but it may as well be written in Chinese for me: https://www.xsimulator.net/communit...etry-output-into-a-game-simple-example.11080/
    This is the Space Monkey app that pulls the telemetry and can output via UDP: https://github.com/PHARTGAMES/SpaceMonkey
    Any guidance here for a caveman?
    TIA
    Moe
    147,878Coins
    +10,880 / 54 / -2
    SimTools can interface with UDP.
    But stepping back a moment as I understand it Space Monkey basically maps controller inputs and makes them available in Xbox controller emulated format. That emulation is what the existing SimTools joystick plugin already does: https://www.xsimulator.net/community/marketplace/joystick-plugin.127/
    And you can expand the joystick plugin functionality using Vjoy: https://www.xsimulator.net/communit...otion-plugin-and-vjoy-controller-mapping.387/
    There are also native SimTools plugins for a bunch of the games Space Monkey supports.
    It is always cool to expand what SimTools can interface with, but I guess I would just like to know what you hope to get out of Space Monkey that is not already available in one form or the other?
    If you want to create a plugin for Space Monkey then see here: https://www.xsimulator.net/communit...lugin-for-simtools-2-0-api-documentation.131/
  3. Moe Colontonio
    New Jersey USA
    758Coins
    Maybe there is another "Space Monkey" out there? This guy wrote this plugin to interface with SimCommander. It pulls telemetry from games and sends it in a format that Sim Commander can use. I never saw anything about joysticks or xbox, but I could be missing something.
    I currently use it to pull telemetry from DCS and send it to SC. I would rather learn how to send it to simtools.
    147,878Coins
    +10,880 / 54 / -2
    This is from the Space Monkey Github explanation:
    SpaceMonkey supports XINPUT, currently mapped to standard gamepad inputs for steering (left stick), accelerator(right trigger), and brake(left trigger). Clutch and axis assignments coming in a future version. Use the XBOX 360 controller emulator to map your direct input devices to an XINPUT gamepad.
  5. Moe Colontonio
    New Jersey USA
    758Coins
    Again, I'm a trash man, not a programmer so maybe I'm missing something.
    I've been using it to pull telemetry from dcs and somehow send it to sim commander. I currently use vjoy to interface with my brunner ffb, but I have no idea how any of that is working.
    SpaceMonkey was created to be a telemetry interface for games with no native telemetry support.
    SpaceMonkey mimics the functionality of the Codemasters Dirt 4 custom udp format which allows SpaceMonkey to be used via the UDP protocol by any software that already supports Dirt 4 and Dirt Rally 2.0 custom udp. SpaceMonkey also optionally writes telemetry to a Memory Mapped File as an alternative to UDP.
    SpaceMonkey contains telemetry visualisation and filtering functionality."
  6. GWiz
    GWiz Active Member
    Dentist
    Aberdeenshire, Scotland
    1,498Coins
    I think you are on to something very interesting here with the SpaceMonkey program. It is not merely a joystick plugin replacement as @noorbeast thought, but does appear to pull lots of different telemetry. I had a fiddle with it and managed to get motion with Wreckfest (Though not working correctly, but it seems a good start). It appears to scan the game to find the telemetry somehow and isn't reliant on constantly updating plugins within Simtools for games that receive frequent updates. If this is true, this could be a real boost to game compatibility. (Assuming this isn't already a feature included in the much anticipated Simtools V3 @yobuddy )
    To answer your question, yes I suspect you can use Simtools to read the UDP from Spacemonkey and convert this to motion for your Gbelt and GSeat, it just needs the correct configuration in Spacemonkey and either an existing or new plugin for Simtools. Exactly how you can achieve this, I haven't quite figured out yet but if I can get it partly working, I'm sure someone with a better grasp on these things will swoop in with an answer soon, this is a great forum for helpful advice.
  7. KydDynoMyte
    RTP, NC
    64Coins
    It looks to me like you would use a Dirt 4 or Dirt Rally 2.0 plugin, space monkey mimics that it is Dirt 4 or Dirt Rally 2.0.
  8. Hocky
    Hocky Member
    123Coins
