Can X-sim communicate with Picaxe chips?
Discussion in 'Miscellaneous' started by xtech007, Aug 16, 2010.
  1. xtech007
    xtech007 Member
    29Coins
    Good Evening Forum.
    My Intentions are to Communicate x-sim via- USO.
    I'm wondering if anyone else have accomplish the communication.
    I have made a control unit that reads of a pot from the steering wheel I personally modified to read Input.
    Another pot installed at the position of the motion mechanism to give position.
    Both communicate to the picaxe 28x1 chip, the chip is programmed to give I2C communication to a MD03 H-bridge to drive Geared DC motor. the direction is driven my a simple math code programmed in the chip, and input by the first pot.
    here is a video of the result:
    http://www.youtube.com/watch?v=pNBx1fkB0CA
    Problem:
    its mechanical, and not realistic to the input of the game but steering wheel input.
    I would like it to actually feel the game inputs driven by the game not my steering wheel.
    anyone's assistance will be greatly appreciated.
  2. egoexpress
    The USO is not able to communicate. The USO is uni-directional.
    You have to configure your hardware to accept commands in the following format:
    (example for 2 axis and a resolution of 255)
    AB~255~~a01~~a02~
    You can get further info here:
    http://www.x-simulator.de/beta/uso.html
    Does your hardware support variable speeds?
  3. xtech007
    xtech007 Member
    29Coins
    Thanks for the fast reply!
    Yes, it can support Variable speeds. I used the speeds to compensate for the speed of the motion to encounter weight of the user. if you notice in the video the machine with no weight in it is jerky, but when I sit on it ( average 180 lbs) is smooth.
    Back to the program side, The Picaxe can Receive and send out Serial communication in the following format:
    serin 7, N9600_16, (AB), b4, b5, b6, b7, b8, b9
    serout 7, N9600_16, (Q, b11, b10, b13, b12, b15, b14)
    this format works with Mr Ian's Hopper BFF Motion Driver software and 64SPU-1 card using a picaxe chip too.
    Problem:
    it only works with FSX. Not Racing simulators.
    if anyone can cross-data between x-sim and BFF Motion Driver software maybe we can get this to work.
  4. Frakk
    Frakk Active Member
    328Coins
    There is no need for feedback.
    Here is what you need to do:
    Configure your picaxe and X-Sim to communicate with the same packet frames. For example: AB~a01~~a01~
    Where AB is just 2x 8bit ascii characters, ~a01~ and ~a02~ is your 2 axis, setup in the Math section. These numbers can be configured 8, 16, 32bits.
    After you receive these axis positions, you just have to substitute them in instead of the ADC result of your potentiometer. Might need to do some scaling and divide or multiply it.
    Use the TestPlugin to make things work and get familiar with it.
    Good luck!!
