Can you simulate roll/pich/yaw etc in Simtools?
Discussion in 'SimTools DIY Version' started by Slider, Sep 22, 2016.
  1. Slider
    Slider Active Member
    Irrigation
    Brisbane
    1,130Coins
    2DOF, JRK
    Let me explain what i mean.
    I can get axis 1 & 2 to move with the slider but the roll/pitch/etc. sliders do not move the machine. Is this normal or have i done something wrong? Seems like a much easier way to test output settings and motor directions?
    147,878Coins
    +10,880 / 54 / -2
    You can go to Output Testing in Game Engine and Turn On Axis Testing, then use the sliders to move each axis/force individually, is that what you are looking for?
  3. Slider
    Irrigation
    Brisbane
    1,130Coins
    2DOF, JRK
    I can move axis 1 and 2 but none of the forces work. What am i doing wrong?
    147,878Coins
    +10,880 / 54 / -2
    Can you please post pictures of all of your settings, that would likely help a lot.
  5. Daguru
    Kitchen installer
    Wales uk
    453Coins
    Motion platform
    Output testing only looks at the default profile in axis assignments not any game profiles so make sure you have pitch,roll,heave etc set in the default profile and then once you turn on output testing you can select output type and swap between dof and axis
    • Agree Agree x 4
  6. Slider
    Irrigation
    Brisbane
    1,130Coins
    2DOF, JRK
    Thanks, im sure its that simple, will try again tonight.
