Cant assign same comport for axis2 ?
Discussion in 'SimTools DIY Version' started by Silvano, May 26, 2015.
  1. Silvano
    Silvano New Member
    348Coins
    2DOF, SCN6
    hi all,
    tryed first setup and probs arise....my 2 axes are on com3 but on axis2 in the droplist i can only assign to com1, so i am stock :(
    any clue?
    147,878Coins
    +10,879 / 54 / -2
    @Silvano I have asked a number of times that you start your own thread and tell us something about your motion rig. It is impossible to offer assistance and troubleshoot for you without knowing what hardware and control boards are involved.
  3. Silvano
    Silvano New Member
    348Coins
    2DOF, SCN6
    ok, this is my own thread unless i am not understanding what you mean by that.
    actuators = 2 x SCN6 150 mm
    1 x USB converter for both SCN6
    both actuators assigned to COM3
    working till now with LOGYKAL E69 motion software
    no control board
    the spec of my rig are in the signature
    tell me if you need more info.
  4. Silvano
    Silvano New Member
    348Coins
    2DOF, SCN6
    147,878Coins
    +10,879 / 54 / -2
  6. nclabs
    196Coins
    Yep, it's easy, you need to set the two actuators on two different com ports, you can't set up both on the same port. You need to find out what com port number are associate with your usb converters.
    Italiano: non puoi mettere tutti e due gli attuatori nella stessa porta com, non può funzionare. Devi guardare nel device manager quali porte com sono associate alle due schede usb e usare quelle porte.
  7. Silvano
    Silvano New Member
    348Coins
    2DOF, SCN6
    @nclabs,
    Its com3, assigning axis1 is ok but for axis2 there is only [com1] to choose from the list. I have ONLY 1 USB converter for both actuators. thats the way it was working with LOGYKAL.
    non capisco piu niente, in inglese tu dici che 2 attuatori possono essere sul la stessa porta com, e in italiano tu dici che non puo funzionare. invece ha funzionato cosi per 2 anni con LOGYKAL.
    scusami ma ce un parradosso tra quel che dici in inglese e in italiano nel tuo messaggio:think
  8. Silvano
    Silvano New Member
    348Coins
    2DOF, SCN6
    Yes I did read that but it doesent help me, my bigest propblem is that both actuators are pluged to one USB converter, so basicaly they both have the same com port (3) and they have been working good since 2 years in that setup.
    The reason I want to change to SIMTOOLS is the lack of new plugins for LOGYKAL motion software.
  9. nclabs
    196Coins
    @Silvano Hai ragione, avevo dimenticato una "t" nella versione inglese. Per utilizzare SimTools hai bisogno di due schede USB (una per ogni attuatore) e regolare il software per funzionare su due com port diverse, altrimenti non può funzionare. C'è scritto anche nella guida se non sbaglio.
    English version: To run with SimTools you need one converter for each actuator, in this case two converters for two actuators, and then you set up the software for use two different com ports. It's written on the guide.
  10. Silvano
    Silvano New Member
    348Coins
    2DOF, SCN6
    @nclabs Well its a pity, so I cant use SIMTOOLS as I am not good enough to do what you say, I wouldnt know where to get 2 converters for my actuators :(
    Beh allora mi fermo qui perche non me la sento di fare quel trafico e non sono sicuro di fare che funziona :(
  11. Silvano
    Silvano New Member
    348Coins
    2DOF, SCN6
    Hi all,
    I found 2 boards converters for SCN6, hopefully its going to work after some fiddling around, thanks @nclabs and all involved :thumbs
